get_started_with_deviationtx [2016/04/15 03:26] FDR [First you need a TX] |
- | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, F4, F7 and F12E, and you can read some opinions here: [[http://www.deviationtx.com/articles/21-which-devo-tx-should-i-buy|Which Devo TX should I buy?]] | + | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] |
Line 10: | Line 10: | ||
Line 17: | Line 17: | ||
Line 45: | Line 45: | ||
Line 59: | Line 59: | ||
get_started_with_deviationtx.txt (54690 views) · Last modified: 2020/01/31 12:43 by laurent_martin
