get_started_with_deviationtx [2017/03/16 09:25] thanh1516 [First you need a TX] |
- | \\ | + | \\devo 7e |
- | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] | + | ...if you don't have one already. The currently supported models include the 6, 6S, 7E. |
Line 9: | Line 8: | ||
Line 16: | Line 15: | ||
Line 44: | Line 43: | ||
Line 58: | Line 57: | ||
get_started_with_deviationtx.txt (87252 views) · Last modified: 2020/01/31 12:43 by laurent_martin
