get_started_with_deviationtx [2016/05/01 01:57] TheSFReader [Install deviation] |
get_started_with_deviationtx [2017/03/16 09:24] thanh1516 [Getting started with deviationTx] |
- | \\ | + | \\devo 7e |
+ | Devo 10 | ||
Line 9: | Line 9: | ||
Line 16: | Line 16: | ||
- | * **"Official" releases, like the 5.0.0** \\ From time to time there is a release, which is tested, and gets a round version number, however they are rare. The last one is 5.0 and was released the 30/05/2016. | + | * **"Official" releases, like the 5.0.0** \\ From time to time there is a release, which is tested, and gets a round version number, however they are rare. The last one is 5.0 and was released the 30/04/2016. |
Line 44: | Line 44: | ||
Line 58: | Line 58: | ||
get_started_with_deviationtx.txt (88130 views) · Last modified: 2020/01/31 12:43 by laurent_martin
