get_started_with_deviationtx [2016/06/30 12:39] Arnold [Ready to fly (or drive, or sail, or whatever)] |
- | ===== First you need a TX ===== | ||
- | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] | ||
+ | ===== First you need a TX ===== | ||
+ | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] | ||
+ | Devo 10 | ||
Line 9: | Line 10: | ||
Line 16: | Line 17: | ||
Line 27: | Line 28: | ||
Line 44: | Line 45: | ||
Line 58: | Line 59: | ||
get_started_with_deviationtx.txt (45567 views) ยท Last modified: 2020/01/31 12:43 by laurent_martin
