get_started_with_deviationtx [2016/10/04 08:47]
extrawai [Getting started with deviationTx]
get_started_with_deviationtx [2020/01/31 12:43]
Line 1: Line 1:
-\\devo 1o+
-...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]]+...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]]
Line 9: Line 10:
 First ensure your TX is supported. DEVO 4, 7, 12E and F12 are not supported at the moment. Some might be supported later, others probably never will be. First ensure your TX is supported. DEVO 4, 7, 12E and F12 are not supported at the moment. Some might be supported later, others probably never will be.
-Second, give deviation a try without any risks: download the emulator, which is a PC program that mimics the user interface of the real TX, so you can see if you like it at all. You can download it for each TX from the [[http://​www.deviationtx.com/​downloads-new/​category/​1-deviation-releases|Deviation Releases]] section of the [[http://​www.deviationtx.com/​downloads-new|Downloads]] menu. Their name start with "​deviation-emu_devo..."​.+Second, give deviation a try without any risks: download the emulator, which is a PC program that mimics the user interface of the real TX, so you can see if you like it at all. You can download it for each TX from the [[https://​www.deviationtx.com/​downloads-new/​category/​1-deviation-releases|Deviation Releases]] section of the [[https://​www.deviationtx.com/​downloads-new|Downloads]] menu. Their name start with "​deviation-emu_devo..."​.
Line 16: Line 17:
 Deviation can be simple to use, but like any sophisticated Radio Control system, there is a learning curve. Do yourself a favor and read the manual. It will ease the transition. Deviation can be simple to use, but like any sophisticated Radio Control system, there is a learning curve. Do yourself a favor and read the manual. It will ease the transition.
-You can read the actual documentation online by clicking on the appropriate User Manual submenu on the left ([[http://​www.deviationtx.com/​user-manual/​user-manual-6-8-12|DEVO 6/8/12]], [[http://​www.deviationtx.com/​user-manual/​user-manual-7e-10|DEVO 7E/10]]), or you can download it as a PDF ([[https://​bitbucket.org/​deviationtx/​deviation-manual-rst/​downloads/​Deviation8UsersManual.pdf|DEVO 6/8/12]], [[https://​bitbucket.org/​deviationtx/​deviation-manual-rst/​downloads/​Deviation10UsersManual.pdf|DEVO 7E/10]]).+You can read the actual documentation online by clicking on the appropriate User Manual submenu on the left ([[https://​www.deviationtx.com/​user-manual/​user-manual-6-8-12|DEVO 6/8/12]], [[https://​www.deviationtx.com/​user-manual/​user-manual-7e-10|DEVO 7E/10]]), or you can download it as a PDF ([[https://​bitbucket.org/​deviationtx/​deviation-manual-rst/​downloads/​Deviation8UsersManual.pdf|DEVO 6/8/12]], [[https://​bitbucket.org/​deviationtx/​deviation-manual-rst/​downloads/​Deviation10UsersManual.pdf|DEVO 7E/10]]).
 ===== Install deviation ===== ===== Install deviation =====
-You can download it for each TX from the [[http://​www.deviationtx.com/​downloads-new/​category/​1-deviation-releases|Deviation Releases]] section of the [[http://​www.deviationtx.com/​downloads-new|Downloads]] menu.+You can download it for each TX from the [[https://​www.deviationtx.com/​downloads-new/​category/​1-deviation-releases|Deviation Releases]] section of the [[https://​www.deviationtx.com/​downloads-new|Downloads]] menu.
 There are three type of releases: There are three type of releases:
Line 27: Line 28:
   * **"​Official"​ releases, like the 5.0.0** \\ From time to time there is a release, which is tested, and gets a round version number, however they are rare. The last one is 5.0 and was released the 30/04/2016.   * **"​Official"​ releases, like the 5.0.0** \\ From time to time there is a release, which is tested, and gets a round version number, however they are rare. The last one is 5.0 and was released the 30/04/2016.
-  * **[[http://​www.deviationtx.com/​downloads-new/​category/​13-nightly-builds|Nightly Builds]]** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too.+  * **[[https://​www.deviationtx.com/​downloads-new/​category/​13-nightly-builds|Nightly Builds]]** \\ They are automatic builds, which are built every night when there is some code change. While they are not that thoroughly tested, they may contain fixes for known bugs of the official release and they also add new features too.
-  * **[[http://​www.deviationtx.com/​downloads-new/​category/​32-test-builds|Test releases]]** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build.+  * **[[https://​www.deviationtx.com/​downloads-new/​category/​32-test-builds|Test releases]]** \\ These releases are made by the individual developers, and contain yet unapproved changes, which need to be tested before they can be merged into the code and appear in the Nightly Builds on the next day. These are often incomplete releases, for example they might not have the filesystem. Usually you need to install the latest Nightly Build before you can try a test build.
Line 37: Line 38:
   * DSM2   * DSM2
   * DSMX   * DSMX
   * Nine Eagles J6Pro   * Nine Eagles J6Pro
-You can find ready to use [[http://​www.deviationtx.com/​forum/​model-configs|model configs in the forum]] or in the [[model_config|Wiki]] for your models, which you can download, and simply copy into your TX through USB, just like you copy to any USB drive.+You can find ready to use [[https://​www.deviationtx.com/​forum/​model-configs|model configs in the forum]] or in the [[model_config|Wiki]] for your models, which you can download, and simply copy into your TX through USB, just like you copy to any USB drive.
Line 58: Line 59:
-If you haven'​t found an answer for your particular question, just ask away in the [[http://​www.deviationtx.com/​forum|Forum]]. However, when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later.+The [[guides|Tutorials and How-Tos]] can also be helpful.
 +If you haven'​t found an answer for your particular question, just ask away in the [[https://​www.deviationtx.com/​forum|Forum]]. However, when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later.
get_started_with_deviationtx.txt (44206 views) · Last modified: 2020/01/31 12:43 by laurent_martin
