get_started_with_deviationtx [2017/02/16 22:16] extrawai [First you need a TX] |
- | \\devo 1o | + | |
...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] |
get_started_with_deviationtx.txt (14346 views) · Last modified: 2020/01/31 12:43 by laurent_martin
