get_started_with_deviationtx [2017/03/16 09:24]
thanh1516 [Getting started with deviationTx]
get_started_with_deviationtx [2020/01/31 12:43]
Line 1: Line 1:
-\\devo 7e+
 ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]]
-Devo 10+
Line 37: Line 38:
   * DSM2   * DSM2
   * DSMX   * DSMX
Line 57: Line 58:
 ===== If you have a question... ===== ===== If you have a question... =====
 +The [[guides|Tutorials and How-Tos]] can also be helpful.
 If you haven'​t found an answer for your particular question, just ask away in the [[https://​www.deviationtx.com/​forum|Forum]]. However, when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later. If you haven'​t found an answer for your particular question, just ask away in the [[https://​www.deviationtx.com/​forum|Forum]]. However, when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later.
get_started_with_deviationtx.txt (43890 views) · Last modified: 2020/01/31 12:43 by laurent_martin
