Next revision Both sides next revision
get_started_with_deviationtx [2017/03/16 09:49]
FDR old revision restored (2017/03/16 12:24)
get_started_with_deviationtx [2017/10/15 13:00]
MikeNH [If you have a question...]
Line 1: Line 1:
-\\devo 7e+
 ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]]
-Devo 10+
Line 57: Line 58:
 ===== If you have a question... ===== ===== If you have a question... =====
 +The *[[guides|Tutorials and How To's]] can also be helpful.
 If you haven'​t found an answer for your particular question, just ask away in the [[https://​www.deviationtx.com/​forum|Forum]]. However, when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later. If you haven'​t found an answer for your particular question, just ask away in the [[https://​www.deviationtx.com/​forum|Forum]]. However, when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later.
get_started_with_deviationtx.txt (43885 views) · Last modified: 2020/01/31 12:43 by laurent_martin
