hardware:devo10
hardware:devo10 [2016/04/15 06:26] PhracturedBlue |
hardware:devo10 [2019/02/25 07:56] PhracturedBlue |
Line 10: | Line 10: | ||
- | | 0 (ADC_IN_10) | AUX4 | + | |0 (ADC_IN_10) |AUX4 | |
- | | 1 (ADC_IN_11) | Left Horizontal Stick | + | |1 (ADC_IN_11) |Left Horizontal Stick | |
- | | 2 (ADC_IN_12) | Right Horizontal stick | + | |2 (ADC_IN_12) |Right Horizontal stick | |
- | | 3 (ADC_IN_13) | Right Vertical Stick | + | |3 (ADC_IN_13) |Right Vertical Stick | |
- | | 4 (ADC_IN_14) | Battery Voltage | + | |4 (ADC_IN_14) |Battery Voltage | |
- | | 5 (ADC_IN_15) | Left Vertical Stick | + | |5 (ADC_IN_15) |Left Vertical Stick | |
- | | 6 | Gear Switch?? | + | |6 |Gear Switch?? | |
- | | 7 | Elevator D/R Switch?? | + | |7 |Elevator D/R Switch?? | |
- | | 8 | Rudder D/R Switch?? | + | |8 |Rudder D/R Switch?? | |
- | | 9 | FMode 0 Switch?? | + | |9 |FMode 0 Switch?? | |
- | | 10 | FMode 2 Switch?? | + | |10 |FMode 2 Switch?? | |
- | | 11 | Aileron D/R Switch?? | + | |11 |Aileron D/R Switch?? | |
- | | 12 | Mix 0 Switch?? | + | |12 |Mix 0 Switch?? | |
- | | 13 | Mix 2 Switch?? | + | |13 |Mix 2 Switch?? | |
- | | 0-1 | LCD Module | + | |0 (FSMC D2) | LCD Module | |
- | | 2 | ??? Push/Pull output default low | + | |1 (FSMC D3) | LCD Module | |
- | | 4-5 | LCD Module | + | |2 |??? Push/Pull output default low | |
- | | 7-11 | LCD Module | + | |4 (FSMC NOE) |LCD Module | |
- | | 14-15 | LCD Module | + | |5 (FSMC NWE) |LCD Module | |
- | | 2 | Button Matrix Row 1 | + | |2 |Button Matrix Row 1 | |
- | | 3 | Button Matrix Row 2 | + | |3 |Button Matrix Row 2 | |
- | | 4 | Button Matrix Row 3 | + | |4 |Button Matrix Row 3 | |
- | | 5 | Button Matrix Row 4 | + | |5 |Button Matrix Row 4 | |
- | | 6 | Button Matrix Row 5 | + | |6 |Button Matrix Row 5 | |
- | | 7-15 | LCD Module | + | |7 (FSMC D4) |LCD Module | |
Line 87: | Line 96: | ||
+ | **TL:** Trim Left | ||
+ | **TR:** Trim Right | ||
+ | **TU:** Trim Up | ||
+ | **TD:** Trim down | ||
+ | ==== FCC Report ==== | ||
hardware/devo10.txt (95768 views) · Last modified: 2019/02/25 07:56 by PhracturedBlue
