hardware:devo10
hardware:devo10 [2016/04/15 08:57] FDR [STM32 Connections] |
hardware:devo10 [2016/04/15 09:00] FDR [Button Matrix] |
Line 10: | Line 10: | ||
- | ^Pin ^ Desription ^ | + | ^Pin ^ Desription ^ |
- | | BOOT0 | CON2 | | + | | BOOT0 | CON2 | |
- | | NRST | Debugger (NRESET) | | + | | NRST | Debugger (NRESET) | |
| 1 | Buzzer | | | 1 | Buzzer | | ||
| 2 | output to 0 to shut off Tx | | | 2 | output to 0 to shut off Tx | | ||
Line 31: | Line 31: | ||
| 1 | LCD Backlight | | | 1 | LCD Backlight | | ||
| 2 (BOOT1) | SPI Flash Chip-Enable | | | 2 (BOOT1) | SPI Flash Chip-Enable | | ||
Line 46: | Line 46: | ||
| 0 (ADC_IN_10) | AUX4 | | | 0 (ADC_IN_10) | AUX4 | | ||
| 1 (ADC_IN_11) | Left Horizontal Stick | | | 1 (ADC_IN_11) | Left Horizontal Stick | | ||
Line 63: | Line 63: | ||
| 0-1 | LCD Module | | | 0-1 | LCD Module | | ||
| 2 | ??? Push/Pull output default low | | | 2 | ??? Push/Pull output default low | | ||
Line 71: | Line 71: | ||
| 2 | Button Matrix Row 1 | | | 2 | Button Matrix Row 1 | | ||
| 3 | Button Matrix Row 2 | | | 3 | Button Matrix Row 2 | | ||
Line 87: | Line 87: | ||
- | | ^ B.6 ^ B.7 ^ B.8 ^ B.9 ^ | + | | ^ B.6 ^ B.7 ^ B.8 ^ B.9 ^ |
- | ^E.2 | L- | DN- | NC | Elevator Trim Down | | + | ^E.2 | L- | DN- | NC | Elevator Trim Down | |
- | ^E.3 | R+ | UP+ | Top Right Trim Down | Throttle Trim Up | | + | ^E.3 | R+ | UP+ | Top Right Trim Down | Throttle Trim Up | |
- | ^E.4 | Ent | Ext | Top Right Trim Up | Elevator Trim Up | | + | ^E.4 | Ent | Ext | Top Right Trim Up | Elevator Trim Up | |
- | ^E.5 | Aileron Trim Right | Rudder Trim Left | Top Left Trim Up | NC | | + | ^E.5 | Aileron Trim Right | Rudder Trim Left | Top Left Trim Up | NC | |
- | ^E.6 | Aileron Trim Left | Rudder Trim Right | Top Left Trim Down | Throttle Trim Down | | + | ^E.6 | Aileron Trim Left | Rudder Trim Right | Top Left Trim Down | Throttle Trim Down | |
hardware/devo10.txt (98880 views) · Last modified: 2019/02/25 07:56 by PhracturedBlue
