hardware:devo10
hardware:devo10 [2016/04/15 06:16] PhracturedBlue created |
- | ===== Devo 10 ===== | + | ~~TOC:3-4~~ |
+ | ===== Devo 10 Hardware Connections ===== | ||
Line 9: | Line 10: | ||
- | ^Pin ^ Desription ^ | + | |BOOT0 |CON2 | |
- | | BOOT0 | CON2 | | + | |NRST |Debugger (NRESET) | |
- | | NRST | Debugger (NRESET) | | + | |
- | GPIOC: | + | === GPIOC === |
+ | ^Pin ^Desription ^ | ||
+ | |0 (ADC_IN_10) |AUX4 | | ||
+ | |1 (ADC_IN_11) |Left Horizontal Stick | | ||
+ | |2 (ADC_IN_12) |Right Horizontal stick | | ||
+ | |3 (ADC_IN_13) |Right Vertical Stick | | ||
+ | |4 (ADC_IN_14) |Battery Voltage | | ||
+ | |5 (ADC_IN_15) |Left Vertical Stick | | ||
+ | |6 |Gear Switch?? | | ||
+ | |7 |Elevator D/R Switch?? | | ||
+ | |8 |Rudder D/R Switch?? | | ||
+ | |9 |FMode 0 Switch?? | | ||
+ | |10 |FMode 2 Switch?? | | ||
+ | |11 |Aileron D/R Switch?? | | ||
+ | |12 |Mix 0 Switch?? | | ||
+ | |13 |Mix 2 Switch?? | | ||
- | 0 (ADC_IN_10): AUX4 | + | === GPIOD === |
- | 1 (ADC_IN_11): Left Horizontal Stick | + | ^Pin ^Desription ^ |
- | 2 (ADC_IN_12): Right Horizontal stick | + | |0 (FSMC D2) | LCD Module | |
- | 3 (ADC_IN_13): Right Vertical Stick | + | |1 (FSMC D3) | LCD Module | |
- | 4 (ADC_IN_14): Battery Voltage | + | |2 |??? Push/Pull output default low | |
- | 5 (ADC_IN_15): Left Vertical Stick | + | |4 (FSMC NOE) |LCD Module | |
- | 6: Gear Switch?? | + | |5 (FSMC NWE) |LCD Module | |
- | 7: Elevator D/R Switch?? | + | |7 (FSMC NE1) |LCD Module (unconnected?) | |
- | 8: Rudder D/R Switch?? | + | |11 (FSMC A16) |LCD Module | |
- | 9: FMode 0 Switch?? | + | |14 (FSMC D0) |LCD Module | |
- | 10: FMode 2 Switch?? | + | |15 (FSMC D1) |LCD Module | |
- | 11: Aileron D/R Switch?? | + | |
- | 12: Mix 0 Switch?? | + | |
- | 13: Mix 2 Switch?? | + | |
- | GPIOD: | + | === GPIOE === |
+ | |2 |Button Matrix Row 1 | | ||
+ | |3 |Button Matrix Row 2 | | ||
+ | |4 |Button Matrix Row 3 | | ||
+ | |5 |Button Matrix Row 4 | | ||
+ | |6 |Button Matrix Row 5 | | ||
+ | |7 (FSMC D4) |LCD Module | | ||
- | 0-1: LCD Module | + | === GPIOF === |
- | 2: ??? Push/Pull output default low | + | \\ |
- | 4-5: LCD Module | + | \\ |
- | 7-11: LCD Module | + | |
- | 14-15: LCD Module | + | |
- | GPIOE: | + | ==== Battery Voltage ==== |
+ | The battery voltage (ADC1_14) is calculated by the formula: | ||
+ | V = 0.003246 * value + 0.4208 | ||
- | 2: Button Matrix Row 1 | + | ==== Button Matrix ==== |
- | 3: Button Matrix Row 2 | + | |
- | 4: Button Matrix Row 3 | + | |
- | 5: Button Matrix Row 4 | + | |
- | 6: Button Matrix Row 5 | + | |
- | 7-15: LCD Module | + | |
- | GPIOF: | + | | ^B.6 ^B.7 ^B.8 ^B.9 ^ |
- | + | ^E.2 |L- |DN- |NC |Elevator TD | | |
- | The battery voltage (ADC1_14) is calculated by the formula: | + | ^E.3 |R+ |UP+ |Top Right TD |Throttle TU | |
- | V = 0.003246 * value + 0.4208 | + | ^E.4 |Ent |Ext |Top Right TU |Elevator TU | |
+ | ^E.5 |Aileron TR |Rudder TL |Top Left TU |NC | | ||
+ | ^E.6 |Aileron TL |Rudder TR |Top Left TD |Throttle TD | | ||
- | Button Matrix: | + | **TL:** Trim Left |
+ | **TR:** Trim Right | ||
+ | **TU:** Trim Up | ||
+ | **TD:** Trim down | ||
- | B.6 B.7 B.8 B.9 | + | ==== FCC Report ==== |
- | E.2 L- DN- NC Elevator Trim Down | + | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|S29 DEVO-10]] |
- | E.3 R+ UP+ Top Right TD Throttle Trim Up | + | |
- | E.4 Ent Ext Top Right TU Elevator Trim Up | + | |
- | E.5 Aileron TR Rudder TL Top Left TU NC | + | |
- | E.6 Aileron TL Rudder TR Top Left TD Throttle Trim Down | + | |
- | TL: Trim Left TR: Trim Right | ||
- | TU: Trim Up TD: Trim Down |
hardware/devo10.1460726206.txt.gz (63459 views) · Last modified: 2016/04/15 06:16 by PhracturedBlue
