hardware:devo10
hardware:devo10 [2016/04/15 08:57] FDR [STM32 Connections] |
| Line 1: | Line 1: | ||
| ~~TOC:3-4~~ | ~~TOC:3-4~~ | ||
| - | ===== Devo 10 ===== | + | ===== Devo 10 Hardware Connections ===== |
| The following documents the hardware inside the Devo-10 transmitter | The following documents the hardware inside the Devo-10 transmitter | ||
| Line 10: | Line 10: | ||
| - | ^Pin ^ Desription ^ | + | ^Pin ^Desription ^ |
| - | | BOOT0 | CON2 | | + | |BOOT0 |CON2 | |
| - | | NRST | Debugger (NRESET) | | + | |NRST |Debugger (NRESET) | |
| - | | 1 | Buzzer | | + | |1 |Buzzer | |
| - | | 2 | output to 0 to shut off Tx | | + | |2 |output to 0 to shut off Tx | |
| - | | 3 | power-switch in 'off' position (goes high on 'off') | | + | |3 |power-switch in 'off' position (goes high on 'off') | |
| - | | 4 (ADC_IN_4) | AUX5 | | + | |4 (ADC_IN_4) |AUX5 | |
| - | | 5 (SPI1_SCK) | SPI Flash, TSC2008 | | + | |5 (SPI1_SCK) |SPI Flash, TSC2008 | |
| - | | 6 (SPI1_MISO) | SPI Flash, TSC2008 | | + | |6 (SPI1_MISO) |SPI Flash, TSC2008 | |
| - | | 7 (SPI1_MOSI) | SPI Flash, TSC2008 | | + | |7 (SPI1_MOSI) |SPI Flash, TSC2008 | |
| - | | 9 (USART1_TX) | Trainer Rx? | | + | |9 (USART1_TX) |Trainer Rx? | |
| - | | 10 (USART1_RX) | Trainer Tx? | | + | |10 (USART1_RX) |Trainer Tx? | |
| - | | 11 (USBDM) | USB+ | | + | |11 (USBDM) |USB+ | |
| - | | 12 (USBDP) | USB- | | + | |12 (USBDP) |USB- | |
| - | | 13 (SWDIO) | Debugger SWDIO (TMS) | | + | |13 (SWDIO) |Debugger SWDIO (TMS) | |
| - | | 1 | LCD Backlight | | + | |1 |LCD Backlight | |
| - | | 2 (BOOT1) | SPI Flash Chip-Enable | | + | |2 (BOOT1) |SPI Flash Chip-Enable | |
| - | | 4 | Button Matrix Col 1 | | + | |4 |Button Matrix Col 1 | |
| - | | 5 | Button Matrix Col 2 | | + | |5 |Button Matrix Col 2 | |
| - | | 8 | Button Matrix Col 3 | | + | |8 |Button Matrix Col 3 | |
| - | | 9 | Button Matrix Col 4 | | + | |9 |Button Matrix Col 4 | |
| - | | 10 | USB Enable (enable Low) | | + | |10 |USB Enable (enable Low) | |
| - | | 11 | TxModule pin 10 - CYRF6936 Reset | | + | |11 |TxModule pin 10 - CYRF6936 Reset | |
| - | | 12 (SPI2_NSS?) | TxModule pin 1 | | + | |12 (SPI2_NSS?) |TxModule pin 1 | |
| - | | 13 (SPI2_SCK?) | TxModule pin 3 | | + | |13 (SPI2_SCK?) |TxModule pin 3 | |
| - | | 14 (SPI2_MISO?) | TxModule pin 9 | | + | |14 (SPI2_MISO?) |TxModule pin 9 | |
| - | | 15 (SPI2_MOSI?) | TxModule pin 7 | | + | |15 (SPI2_MOSI?) |TxModule pin 7 | |
| === GPIOC === | === GPIOC === | ||
| - | | 0 (ADC_IN_10) | AUX4 | | + | |0 (ADC_IN_10) |AUX4 | |
| - | | 1 (ADC_IN_11) | Left Horizontal Stick | | + | |1 (ADC_IN_11) |Left Horizontal Stick | |
| - | | 2 (ADC_IN_12) | Right Horizontal stick | | + | |2 (ADC_IN_12) |Right Horizontal stick | |
| - | | 3 (ADC_IN_13) | Right Vertical Stick | | + | |3 (ADC_IN_13) |Right Vertical Stick | |
| - | | 4 (ADC_IN_14) | Battery Voltage | | + | |4 (ADC_IN_14) |Battery Voltage | |
| - | | 5 (ADC_IN_15) | Left Vertical Stick | | + | |5 (ADC_IN_15) |Left Vertical Stick | |
| - | | 6 | Gear Switch?? | | + | |6 |Gear Switch?? | |
| - | | 7 | Elevator D/R Switch?? | | + | |7 |Elevator D/R Switch?? | |
| - | | 8 | Rudder D/R Switch?? | | + | |8 |Rudder D/R Switch?? | |
| - | | 9 | FMode 0 Switch?? | | + | |9 |FMode 0 Switch?? | |
| - | | 10 | FMode 2 Switch?? | | + | |10 |FMode 2 Switch?? | |
| - | | 11 | Aileron D/R Switch?? | | + | |11 |Aileron D/R Switch?? | |
| - | | 12 | Mix 0 Switch?? | | + | |12 |Mix 0 Switch?? | |
| - | | 13 | Mix 2 Switch?? | | + | |13 |Mix 2 Switch?? | |
| - | | 0-1 | LCD Module | | + | |0 (FSMC D2) | LCD Module | |
| - | | 2 | ??? Push/Pull output default low | | + | |1 (FSMC D3) | LCD Module | |
| - | | 4-5 | LCD Module | | + | |2 |??? Push/Pull output default low | |
| - | | 7-11 | LCD Module | | + | |4 (FSMC NOE) |LCD Module | |
| - | | 14-15 | LCD Module | | + | |5 (FSMC NWE) |LCD Module | |
| + | |7 (FSMC NE1) |LCD Module (unconnected?) | | ||
| + | |11 (FSMC A16) |LCD Module | | ||
| + | |14 (FSMC D0) |LCD Module | | ||
| + | |15 (FSMC D1) |LCD Module | | ||
| - | | 2 | Button Matrix Row 1 | | + | |2 |Button Matrix Row 1 | |
| - | | 3 | Button Matrix Row 2 | | + | |3 |Button Matrix Row 2 | |
| - | | 4 | Button Matrix Row 3 | | + | |4 |Button Matrix Row 3 | |
| - | | 5 | Button Matrix Row 4 | | + | |5 |Button Matrix Row 4 | |
| - | | 6 | Button Matrix Row 5 | | + | |6 |Button Matrix Row 5 | |
| - | | 7-15 | LCD Module | | + | |7 (FSMC D4) |LCD Module | |
| + | |8 (FSMC D5) |LCD Module | | ||
| + | |9 (FSMC D6) |LCD Module | | ||
| + | |10 (FSMC D7) |LCD Module | | ||
| === GPIOF === | === GPIOF === | ||
| ==== Battery Voltage ==== | ==== Battery Voltage ==== | ||
| Line 87: | Line 96: | ||
| ==== Button Matrix ==== | ==== Button Matrix ==== | ||
| - | | ^ B.6 ^ B.7 ^ B.8 ^ B.9 ^ | + | | ^B.6 ^B.7 ^B.8 ^B.9 ^ |
| - | ^E.2 | L- | DN- | NC | Elevator Trim Down | | + | ^E.2 |L- |DN- |NC |Elevator TD | |
| - | ^E.3 | R+ | UP+ | Top Right Trim Down | Throttle Trim Up | | + | ^E.3 |R+ |UP+ |Top Right TD |Throttle TU | |
| - | ^E.4 | Ent | Ext | Top Right Trim Up | Elevator Trim Up | | + | ^E.4 |Ent |Ext |Top Right TU |Elevator TU | |
| - | ^E.5 | Aileron Trim Right | Rudder Trim Left | Top Left Trim Up | NC | | + | ^E.5 |Aileron TR |Rudder TL |Top Left TU |NC | |
| - | ^E.6 | Aileron Trim Left | Rudder Trim Right | Top Left Trim Down | Throttle Trim Down | | + | ^E.6 |Aileron TL |Rudder TR |Top Left TD |Throttle TD | |
| + | **TL:** Trim Left | ||
| + | **TR:** Trim Right | ||
| + | **TU:** Trim Up | ||
| + | **TD:** Trim down | ||
| + | ==== FCC Report ==== | ||
| + | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|S29 DEVO-10]] | ||
hardware/devo10.1460735837.txt.gz (9613 views) · Last modified: 2016/04/15 08:57 by FDR
