hardware:devo10
hardware:devo10 [2016/04/15 09:00] FDR [Button Matrix] |
Line 10: | Line 10: | ||
- | | 0-1 | LCD Module | | + | |0 (FSMC D2) | LCD Module | |
- | | 2 | ??? Push/Pull output default low | | + | |1 (FSMC D3) | LCD Module | |
- | | 4-5 | LCD Module | | + | |2 |??? Push/Pull output default low | |
- | | 7-11 | LCD Module | | + | |4 (FSMC NOE) |LCD Module | |
- | | 14-15 | LCD Module | | + | |5 (FSMC NWE) |LCD Module | |
- | | 7-15 | LCD Module | | + | |7 (FSMC D4) |LCD Module | |
Line 87: | Line 96: | ||
+ | **TL:** Trim Left | ||
+ | **TR:** Trim Right | ||
+ | **TU:** Trim Up | ||
+ | **TD:** Trim down | ||
+ | ==== FCC Report ==== | ||
hardware/devo10.1460736024.txt.gz (65474 views) · Last modified: 2016/04/15 09:00 by FDR
