hardware:devo10
hardware:devo10 [2016/04/15 09:19]
FDR [STM32 Connections]
hardware:devo10 [2019/02/25 07:56] (current)
PhracturedBlue
Line 1: Line 1:
 ~~TOC:3-4~~ ~~TOC:3-4~~
-===== Devo 10 =====+===== Devo 10 Hardware Connections ​=====
 The following documents the hardware inside the Devo-10 transmitter The following documents the hardware inside the Devo-10 transmitter
Line 10: Line 10:
-^Pin  ^ Desription ​ ^ +^Pin    ^Desription ​        ​^
-| BOOT0  | CON2  | +|BOOT0 ​ |CON2               ​|
-| NRST  | Debugger (NRESET) ​ |+|NRST   ​|Debugger (NRESET) ​ |
 === GPIOA === === GPIOA ===
-^Pin  ^ Desription ​ ^ +^Pin             ​^Desription ​                                          ​^
-| 1  | Buzzer ​ | +|1               ​|Buzzer ​                                              ​|
-| 2  | output to 0 to shut off Tx  | +|2               ​|output to 0 to shut off Tx                           ​|
-| 3  | power-switch in '​off'​ position (goes high on '​off'​) ​ | +|3               ​|power-switch in '​off'​ position (goes high on '​off'​) ​ |
-| 4 (ADC_IN_4) ​ | AUX5  | +|4 (ADC_IN_4) ​   |AUX5                                                 ​|
-| 5 (SPI1_SCK) ​ | SPI Flash, TSC2008 ​ | +|5 (SPI1_SCK) ​   |SPI Flash, TSC2008 ​                                  ​|
-| 6 (SPI1_MISO) ​ | SPI Flash, TSC2008 ​ | +|6 (SPI1_MISO) ​  ​|SPI Flash, TSC2008 ​                                  ​|
-| 7 (SPI1_MOSI) ​ | SPI Flash, TSC2008 ​ | +|7 (SPI1_MOSI) ​  ​|SPI Flash, TSC2008 ​                                  ​|
-| 9 (USART1_TX) ​ | Trainer Rx?  | +|9 (USART1_TX) ​  ​|Trainer Rx?                                          |
-| 10 (USART1_RX) ​ | Trainer Tx?  | +|10 (USART1_RX) ​ |Trainer Tx?                                          |
-| 11 (USBDM) ​ | USB+  | +|11 (USBDM) ​     |USB+                                                 ​|
-| 12 (USBDP) ​ | USB-  | +|12 (USBDP) ​     |USB-                                                 ​|
-| 13 (SWDIO) ​ | Debugger SWDIO (TMS)  | +|13 (SWDIO) ​     |Debugger SWDIO (TMS)                                 ​|
-| 14 (SWCLK) ​ | Debugger SWCLK (TCK)  |+|14 (SWCLK) ​     |Debugger SWCLK (TCK)                                 ​|
 === GPIOB === === GPIOB ===
-^Pin  ^ Desription ​ ^ +^Pin              ^Desription ​                       ^
-| 1  | LCD Backlight ​ | +|1                |LCD Backlight ​                    ​|
-| 2 (BOOT1) ​ | SPI Flash Chip-Enable ​ | +|2 (BOOT1) ​       |SPI Flash Chip-Enable ​            ​|
-| 4  | Button Matrix Col 1  | +|4                |Button Matrix Col 1               ​|
-| 5  | Button Matrix Col 2  | +|5                |Button Matrix Col 2               ​|
-| 8  | Button Matrix Col 3  | +|8                |Button Matrix Col 3               ​|
-| 9  | Button Matrix Col 4  | +|9                |Button Matrix Col 4               ​|
-| 10  | USB Enable (enable Low)  | +|10               ​|USB Enable (enable Low)           ​|
-| 11  | TxModule pin 10 - CYRF6936 Reset  | +|11               ​|TxModule pin 10 - CYRF6936 Reset  |
-| 12 (SPI2_NSS?​) ​ | TxModule pin 1  | +|12 (SPI2_NSS?​) ​  ​|TxModule pin 1                    |
-| 13 (SPI2_SCK?​) ​ | TxModule pin 3  | +|13 (SPI2_SCK?​) ​  ​|TxModule pin 3                    |
-| 14 (SPI2_MISO?​) ​ | TxModule pin 9  | +|14 (SPI2_MISO?​) ​ |TxModule pin 9                    |
-| 15 (SPI2_MOSI?​) ​ | TxModule pin 7  |+|15 (SPI2_MOSI?​) ​ |TxModule pin 7                    |
 === GPIOC === === GPIOC ===
-| 0 (ADC_IN_10) ​ | AUX4  | +|0 (ADC_IN_10) ​ |AUX4                    |
-| 1 (ADC_IN_11) ​ | Left Horizontal Stick  | +|1 (ADC_IN_11) ​ |Left Horizontal Stick   ​|
-| 2 (ADC_IN_12) ​ | Right Horizontal stick  | +|2 (ADC_IN_12) ​ |Right Horizontal stick  |
-| 3 (ADC_IN_13) ​ | Right Vertical Stick  | +|3 (ADC_IN_13) ​ |Right Vertical Stick    |
-| 4 (ADC_IN_14) ​ | Battery Voltage ​ | +|4 (ADC_IN_14) ​ |Battery Voltage ​        ​|
-| 5 (ADC_IN_15) ​ | Left Vertical Stick  | +|5 (ADC_IN_15) ​ |Left Vertical Stick     ​|
-| 6  | Gear Switch?? ​ | +|6              |Gear Switch?? ​          ​|
-| 7  | Elevator D/R Switch?? ​ | +|7              |Elevator D/R Switch?? ​  ​|
-| 8  | Rudder D/R Switch?? ​ | +|8              |Rudder D/R Switch?? ​    ​|
-| 9  | FMode 0 Switch?? ​ | +|9              |FMode 0 Switch?? ​       |
-| 10  | FMode 2 Switch?? ​ | +|10             ​|FMode 2 Switch?? ​       |
-| 11  | Aileron D/R Switch?? ​ | +|11             ​|Aileron D/R Switch?? ​   |
-| 12  | Mix 0 Switch?? ​ | +|12             ​|Mix 0 Switch?? ​         |
-| 13  | Mix 2 Switch?? ​ |+|13             ​|Mix 2 Switch?? ​         |
 === GPIOD === === GPIOD ===
-| 0-1  | LCD Module ​ | +|0 (FSMC D2)   | LCD Module ​                      |
-| 2  | ??? Push/Pull output default low  | +|1 (FSMC D3)   | LCD Module ​                      ​|
-| 4-5  | LCD Module ​ | +|2      |??? Push/Pull output default low         ​|
-| 7-11  | LCD Module ​ | +|4 (FSMC NOE)  |LCD Module ​                       |
-| 14-15  | LCD Module ​ |+|5 (FSMC NWE)  |LCD Module ​                       ​|
 +|7 (FSMC NE1)  |LCD Module ​(unconnected?​) ​        |
 +|11 (FSMC A16) |LCD Module ​                       ​|
 +|14 (FSMC D0)  |LCD Module ​                       |
 +|15 (FSMC D1)  |LCD Module ​                       ​|
 === GPIOE === === GPIOE ===
-| 2  | Button Matrix Row 1  | +|2     ​|Button Matrix Row 1  |
-| 3  | Button Matrix Row 2  | +|3     ​|Button Matrix Row 2  |
-| 4  | Button Matrix Row 3  | +|4     ​|Button Matrix Row 3  |
-| 5  | Button Matrix Row 4  | +|5     ​|Button Matrix Row 4  |
-| 6  | Button Matrix Row 5  | +|6     ​|Button Matrix Row 5  |
-| 7-15  | LCD Module ​ |+|7 (FSMC D4)  |LCD Module ​                       |
 +|8 (FSMC D5)  |LCD Module ​                       |
 +|9 (FSMC D6)  |LCD Module ​                       |
 +|10 (FSMC D7)  |LCD Module ​                       ​|
 === GPIOF === === GPIOF ===
Line 89: Line 96:
 ==== Button Matrix ==== ==== Button Matrix ====
-|      ^ B.6         ^ B.7       ​^ B.8           ^ B.9  ^ +|     ​^B.6         ​^B.7 ​       ^B.8           ​^B.9 ​         ^
-^E.2   ​| L-          | DN-       ​| NC            | Elevator ​Trim Down  | +^E.2  |L-          |DN-        |NC            |Elevator ​TD  |
-^E.3   ​| R+          | UP+       ​| Top Right Trim Down  | Throttle ​Trim Up  | +^E.3  |R+          |UP+        |Top Right TD  ​|Throttle ​TU  |
-^E.4   ​| Ent         | Ext       ​| Top Right Trim Up  | Elevator ​Trim Up  | +^E.4  |Ent         ​|Ext ​       |Top Right TU  ​|Elevator ​TU  |
-^E.5   ​| Aileron ​Trim Right  | Rudder ​Trim Left | Top Left Trim Up   | NC         ​| +^E.5  |Aileron ​TR  ​|Rudder ​TL  ​|Top Left TU   |NC           ​|
-^E.6   ​| Aileron ​Trim Left  | Rudder ​Trim Right | Top Left Trim Down   | Throttle Trim Down |+^E.6  |Aileron ​TL  ​|Rudder ​TR  ​|Top Left TD   |Throttle ​TD  |
 +**TL:​** ​Trim Left
 +**TR:** Trim Right
 +**TU:** Trim Up
 +**TD:** Trim down
 +==== FCC Report ====
 +FCCID: [[https://​www.fcc.gov/​general/​fcc-id-search-page|S29 DEVO-10]]
hardware/devo10.1460737166.txt.gz (7909 views) · Last modified: 2016/04/15 09:19 by FDR
