hardware:devo10
hardware:devo10 [2016/04/15 14:52] FDR |
Line 64: | Line 64: | ||
^Pin ^Desription ^ | ^Pin ^Desription ^ | ||
- | |0-1 |LCD Module | | + | |0 (FSMC D2) | LCD Module | |
- | |2 |??? Push/Pull output default low | | + | |1 (FSMC D3) | LCD Module | |
- | |4-5 |LCD Module | | + | |2 |??? Push/Pull output default low | |
- | |7-11 |LCD Module | | + | |4 (FSMC NOE) |LCD Module | |
- | |14-15 |LCD Module | | + | |5 (FSMC NWE) |LCD Module | |
Line 77: | Line 81: | ||
|5 |Button Matrix Row 4 | | |5 |Button Matrix Row 4 | | ||
|6 |Button Matrix Row 5 | | |6 |Button Matrix Row 5 | | ||
- | |7-15 |LCD Module | | + | |7 (FSMC D4) |LCD Module | |
Line 100: | Line 107: | ||
**TU:** Trim Up | **TU:** Trim Up | ||
+ | ==== FCC Report ==== | ||
hardware/devo10.1460757157.txt.gz (79754 views) · Last modified: 2016/04/15 14:52 by FDR
