hardware:devo7e
hardware:devo7e [2016/04/20 07:23] PhracturedBlue |
hardware:devo7e [2016/06/01 04:02] silpstream Update SPI2 Pins |
Line 41: | Line 41: | ||
|10 |USB Enable (enable Low) | | |10 |USB Enable (enable Low) | | ||
|11 |TxModule pin 10 - CYRF6936 Reset | | |11 |TxModule pin 10 - CYRF6936 Reset | | ||
- | |12 (SPI2_NSS?) |TxModule pin 1 | | + | |12 (SPI2_NSS) |TxModule pin 1 | |
- | |13 (SPI2_SCK?) |TxModule pin 3 | | + | |13 (SPI2_SCK) |TxModule pin 2 | |
- | |14 (SPI2_MISO?) |TxModule pin 9 | | + | |14 (SPI2_MISO) |TxModule pin 4 | |
- | |15 (SPI2_MOSI?) |TxModule pin 7 | | + | |15 (SPI2_MOSI) |TxModule pin 3 | |
Line 72: | Line 72: | ||
- | ^C.6 |Rudder TL |NC |Throttle TU |NC | | + | ^C.6 |Aileron TR |NC |Throttle TU |NC | |
- | ^C.7 |Rudder TR |Ent |Throttle TD |DN- | | + | ^C.7 |Aileron TL |Ent |Throttle TD |DN- | |
- | ^C.8 |Elevator TU |R+ |Aileron TR |UP+ | | + | ^C.8 |Elevator TU |R+ |Rudder TL |UP+ | |
- | ^C.9 |Elevator TD |L- |Aileron TL |Ext | | + | ^C.9 |Elevator TD |L- |Rudder TR |Ext | |
Line 82: | Line 82: | ||
FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|S29 DEVO-7E]] | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|S29 DEVO-7E]] | ||
hardware/devo7e.txt (4020 views) · Last modified: 2016/06/01 04:02 by silpstream
