hardware:devo8
hardware:devo8 [2016/04/15 09:23]
PhracturedBlue created
hardware:devo8 [2016/04/20 07:26] (current)
PhracturedBlue
Line 1: Line 1:
 ~~TOC:3-4~~ ~~TOC:3-4~~
-===== Devo 8 =====+===== Devo 8 Hardware Connections ​=====
 The following documents the hardware inside the Devo-8 transmitter The following documents the hardware inside the Devo-8 transmitter
Line 11: Line 12:
-^Pin ^ Desription ^ +^Pin    ^Desription ​        ​
-|BOOT0 | CON2 | +|BOOT0 ​ |CON2               ​
-|NRST | Debugger (NRESET) |+|NRST   ​|Debugger (NRESET) ​ |
 === GPIOA === === GPIOA ===
-^Pin ^ Desription ^ +^Pin             ​^Desription ​                                          ​
-| 1 |  Buzzer | +|1               ​|Buzzer ​                                              ​
-| 2 |  output to 0 to shut off Tx??? | +|2               ​|output to 0 to shut off Tx???
-| 3 |  power-switch in '​off'​ position (goes high on '​off'​) | +|3               ​|power-switch in '​off'​ position (goes high on '​off'​) ​
-| 5 (SPI1_SCK) |  SPI Flash, TSC2008 | +|5 (SPI1_SCK) ​   |SPI Flash, TSC2008 ​                                  ​
-| 6 (SPI1_MISO) |  SPI Flash, TSC2008 | +|6 (SPI1_MISO) ​  ​|SPI Flash, TSC2008 ​                                  ​
-| 7 (SPI1_MOSI) |  SPI Flash, TSC2008 | +|7 (SPI1_MOSI) ​  ​|SPI Flash, TSC2008 ​                                  ​
-| 9 (USART1_TX) |  Trainer Rx? | +|9 (USART1_TX) ​  ​|Trainer Rx?
-| 10 (USART1_RX) ​ ​Trainer Tx? | +|10 (USART1_RX)  ​|Trainer Tx?
-| 11 (USBDM) |  USB+ | +|11 (USBDM) ​     |USB+                                                 ​
-| 12 (USBDP) |  USB- | +|12 (USBDP) ​     |USB-                                                 ​
-| 13 (SWDIO) |  Debugger SWDIO (TMS) | +|13 (SWDIO) ​     |Debugger SWDIO (TMS)                                 ​
-| 14 (SWCLK) |  Debugger SWCLK (TCK) |+|14 (SWCLK) ​     |Debugger SWCLK (TCK)                                 ​|
 === GPIOB === === GPIOB ===
- +^Pin              ^Desription ​
-^Pin ^ Desription ^ +|0                |TSC2008 Chip-Enable ​              ​
-| 0 |  TSC2008 Chip-Enable | +|1                |LCD Module (Backlight control?​) ​  ​
-| 1 |  LCD Module (Backlight control?) | +|2 (BOOT1) ​       |SPI Flash Chip-Enable ​            ​
-| 2 (BOOT1) |  SPI Flash Chip-Enable | +|5                |TSC2008 Pin 15 Pen/​Irq ​
-| 5 |  TSC2008 Pin 15 Pen/Irq | +|6                |Button Matrix Col 1               ​
-| 6 |  Button Matrix Col 1 | +|7                |Button Matrix Col 2               ​
-| 7 |  Button Matrix Col 2 | +|8                |Button Matrix Col 3               ​
-| 8 |  Button Matrix Col 3 | +|9                |Button Matrix Col 4               ​
-| 9 |  Button Matrix Col 4 | +|10               ​|USB Enable (enable Low)           ​
-| 10 |  USB Enable (enable Low) | +|11               ​|TxModule pin 10 - CYRF6936 Reset
-| 11 |  TxModule pin 10 - CYRF6936 Reset | +|12 (SPI2_NSS?​) ​  ​|TxModule pin 1
-| 12 (SPI2_NSS?) |  TxModule pin 1 | +|13 (SPI2_SCK?​) ​  ​|TxModule pin 3
-| 13 (SPI2_SCK?) |  TxModule pin 3 | +|14 (SPI2_MISO?​)  ​|TxModule pin 9
-| 14 (SPI2_MISO?​) ​ ​TxModule pin 9 | +|15 (SPI2_MOSI?​)  ​|TxModule pin 7                    |
-| 15 (SPI2_MOSI?​) ​ ​TxModule pin 7 |+
 === GPIOC === === GPIOC ===
-^Pin ^ Desription ^ +|0 (ADC_IN_10) ​ |Elevator Stick
-| 0 (ADC_IN_10) |  Elevator Stick | +|1 (ADC_IN_11)  ​|Rudder Stick
-| 1 (ADC_IN_11) ​ ​Rudder Stick | +|2 (ADC_IN_12)  ​|Aileron Stick                   ​
-| 2 (ADC_IN_12) ​ ​Aileron Stick | +|3 (ADC_IN_13)  ​|Throttle Stick
-| 3 (ADC_IN_13) ​ ​Throttle Stick | +|4 (ADC_IN_14) ​ |Battery Voltage ​                ​
-| 4 (ADC_IN_14) |  Battery Voltage | +|6              |Gear Switch ​                    ​
-| 6 |  Gear Switch | +|7              |Elevator D/R Switch ​            ​
-| 7 |  Elevator D/R Switch | +|8              |Rudder D/R Switch ​              ​
-| 8 |  Rudder D/R Switch | +|9              |FMode 0 Switch ​
-| 9 |  FMode 0 Switch | +|10             ​|FMode 2 Switch ​
-| 10 |  FMode 2 Switch | +|11             ​|Aileron D/R Switch ​
-| 11 |  Aileron D/R Switch | +|12             ​|Mix 0 Switch ​
-| 12 |  Mix 0 Switch | +|13             ​|Mix 2 Switch ​
-| 13 |  Mix 2 Switch | +|14             ​|Charging (Active Low)           ​
-| 14 |  Charging (Active Low) | +|15             ​|Powered by Outlet (Active Low)  |
-| 15 |  Powered by Outlet (Active Low) |+
 === GPIOD === === GPIOD ===
-^Pin ^ Desription ^ +|0-1    |LCD Module ​
-| 0-1 |  LCD Module | +|4-5    |LCD Module ​
-| 4-5 |  LCD Module | +|7-11   ​|LCD Module ​
-| 7-11 |  LCD Module | +|14-15  ​|LCD Module ​ |
-| 14-15  LCD Module |+
 === GPIOE === === GPIOE ===
-| 2 |  Button Matrix Row 1 | +|2     ​|Button Matrix Row 1
-| 3 |  Button Matrix Row 2 | +|3     ​|Button Matrix Row 2
-| 4 |  Button Matrix Row 3 | +|4     ​|Button Matrix Row 3
-| 5 |  Button Matrix Row 4 | +|5     ​|Button Matrix Row 4
-| 6 |  Button Matrix Row 5 | +|6     ​|Button Matrix Row 5
-| 7-15  LCD Module |+|7-15  ​|LCD Module ​          ​|
 === GPIOF === === GPIOF ===
 ==== Button Matrix ==== ==== Button Matrix ====
-   ^ B.6        ^ B.7       ​^ B.8          ^ B.9 ^ +    ​^B.6         ​^B.7        ^B.8           ​^B.9
-^E.2 | L-         ​| DN-       ​| NC           ​| Elevator ​Trim Down +^E.2  |L-          |DN-        |NC            |Elevator ​TD  ​
-^E.3 | R+         ​| UP+       ​| Top Right Trim Down | Throttle ​Trim Up +^E.3  |R+          |UP+        |Top Right TD  ​|Throttle ​TU  ​
-^E.4 | Ent        | Ext       ​| Top Right Trim Up | Elevator ​Trim Up +^E.4  |Ent         ​|Ext        |Top Right TU  ​|Elevator ​TU  ​
-^E.5 | Aileron ​Trim Right | Rudder ​Trim Left | Top Left Trim Up  ​| NC                 ​+^E.5  |Aileron ​TR  ​|Rudder ​TL  ​|Top Left TU   |NC           ​
-^E.6 | Aileron ​Trim Left | Rudder ​Trim Right | Top Left Trim Down  ​| Throttle Trim Down |+^E.6  |Aileron ​TL  ​|Rudder ​TR  ​|Top Left TD   |Throttle ​TD  |
 +**TL:​** ​Trim Left
 +**TR:** Trim Right
 +**TU:** Trim Up
 +**TD:** Trim down
 +==== FCC Report ====
 +FCCID: [[https://​www.fcc.gov/​general/​fcc-id-search-page|S29 DEVO-8]]
hardware/devo8.1460737430.txt.gz (4427 views) · Last modified: 2016/04/15 09:23 by PhracturedBlue
