hardware:devof4
hardware:devof4 [2016/04/20 07:18] PhracturedBlue created |
hardware:devof4 [2016/04/20 07:28] PhracturedBlue |
- | ===== Devo F7 Hardware Connections ===== | + | ===== Devo F4 Hardware Connections ===== |
The following documents the hardware inside the Devo-F7 transmitter | The following documents the hardware inside the Devo-F7 transmitter | ||
Line 94: | Line 94: | ||
- | Scheamtic available here courtesy of user Buoncristiani: | + | Schematic available here courtesy of user Buoncristiani: |
{{:hardware:schemadevof4.pdf|}} | {{:hardware:schemadevof4.pdf|}} | ||
hardware/devof4.txt (106465 views) · Last modified: 2017/04/14 11:25 by SirDomsen
