hardware:devof4
hardware:devof4 [2016/04/20 07:18] PhracturedBlue created |
hardware:devof4 [2017/01/23 00:52] FDR https |
- | ===== Devo F7 Hardware Connections ===== | + | ===== Devo F4 Hardware Connections ===== |
Line 68: | Line 68: | ||
Line 84: | Line 84: | ||
Line 94: | Line 95: | ||
- | Scheamtic available here courtesy of user Buoncristiani: | + | Schematic available here courtesy of user Buoncristiani: |
hardware/devof4.txt (94202 views) · Last modified: 2017/04/14 11:25 by SirDomsen
