hardware:devof4
hardware:devof4 [2016/04/20 07:19] PhracturedBlue |
hardware:devof4 [2016/04/20 07:23] PhracturedBlue |
- | ===== Devo F7 Hardware Connections ===== | + | ===== Devo F4 Hardware Connections ===== |
The following documents the hardware inside the Devo-F7 transmitter | The following documents the hardware inside the Devo-F7 transmitter | ||
Line 95: | Line 95: | ||
=== FCC Report === | === FCC Report === | ||
{{:hardware:schemadevof4.pdf|}} | {{:hardware:schemadevof4.pdf|}} | ||
hardware/devof4.txt (106467 views) ยท Last modified: 2017/04/14 11:25 by SirDomsen
