hardware:devof4
hardware:devof4 [2016/04/20 07:28] PhracturedBlue |
hardware:devof4 [2017/04/14 11:25] SirDomsen [FCC Report] |
Line 2: | Line 2: | ||
Line 68: | Line 68: | ||
Line 84: | Line 84: | ||
Line 98: | Line 99: | ||
+ | ==== Switch MOD for DEVO F4 ==== | ||
+ | see [[https://www.deviationtx.com/forum/7-development/4976-deviation-for-devo-f4?start=240#47013|this post]] | ||
hardware/devof4.txt (95730 views) · Last modified: 2017/04/14 11:25 by SirDomsen
