hardware:devof4
hardware:devof4 [2016/04/20 07:22] PhracturedBlue |
hardware:devof4 [2017/04/14 11:25] (current) SirDomsen [FCC Report] |
Line 2: | Line 2: | ||
Line 68: | Line 68: | ||
Line 84: | Line 84: | ||
Line 94: | Line 95: | ||
- | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|FCCID:S29 DEVO-F4]] | + | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|S29 DEVO-F4]] |
+ | ==== Switch MOD for DEVO F4 ==== | ||
+ | see [[https://www.deviationtx.com/forum/7-development/4976-deviation-for-devo-f4?start=240#47013|this post]] | ||
hardware/devof4.1461162133.txt.gz (89266 views) · Last modified: 2016/04/20 07:22 by PhracturedBlue
