hardware:jumper_t12
hardware:jumper_t12 [2019/01/26 06:07] PhracturedBlue |
hardware:jumper_t12 [2019/04/26 15:20] goebish [FCC Report] |
Line 18: | Line 19: | ||
Line 31: | Line 32: | ||
|3 |??? | | |3 |??? | | ||
Line 41: | Line 42: | ||
Line 52: | Line 53: | ||
|0 (ADC_IN_10) |Voltage detect | | |0 (ADC_IN_10) |Voltage detect | | ||
- | |2 |Buttom 'Trim RVU' | | + | |2 |Button 'Trim RVU' | |
- | |3 |Buttom 'Trim RVD' | | + | |3 |Button 'Trim RVD' | |
Line 69: | Line 70: | ||
Line 80: | Line 81: | ||
|10 |??? | | |10 |??? | | ||
- | |11 |Switch: C_11 | | + | |11 |Switch: C_L | |
|12 |LCD RST | | |12 |LCD RST | | ||
Line 115: | Line 116: | ||
- | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|XYF X91216DK]] | + | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|2ANTI-T12]] |
hardware/jumper_t12.txt (59754 views) · Last modified: 2019/04/26 15:22 by goebish
