hardware:jumper_t12
hardware:jumper_t12 [2019/01/26 06:41] PhracturedBlue |
hardware:jumper_t12 [2019/02/13 20:50] PhracturedBlue |
Line 32: | Line 33: | ||
|0 (ADC_IN_8) |POT2 | | |0 (ADC_IN_8) |POT2 | | ||
|3 |??? | | |3 |??? | | ||
Line 41: | Line 42: | ||
Line 54: | Line 55: | ||
|2 |Button 'Trim RVU' | | |2 |Button 'Trim RVU' | | ||
|3 |Button 'Trim RVD' | | |3 |Button 'Trim RVD' | | ||
Line 69: | Line 70: | ||
Line 84: | Line 85: | ||
=== GPIOE === | === GPIOE === |
hardware/jumper_t12.txt (60628 views) · Last modified: 2019/04/26 15:22 by goebish
