hardware:jumper_t12
hardware:jumper_t12 [2019/01/26 06:07] PhracturedBlue |
hardware:jumper_t12 [2019/04/26 15:22] (current) goebish [FCC Report] |
| Line 6: | Line 6: | ||
| * Radio: Jumper 4-in-1 module plugged into the back of the transmitter | * Radio: Jumper 4-in-1 module plugged into the back of the transmitter | ||
| * 256kbit EEPROM: ST M24256 | * 256kbit EEPROM: ST M24256 | ||
| + | * Volume control: LM4875 - Controlled via I2C potentiometer (TPL0401B?) | ||
| Line 18: | Line 19: | ||
| |4 |Audio Out | | |4 |Audio Out | | ||
| |5 |Switch B_H | | |5 |Switch B_H | | ||
| - | |6 (ADC_IN_6) |POT1 | | + | |6 (ADC_IN_6) |AUX5 POT | |
| |7 |Ext Module TX | | |7 |Ext Module TX | | ||
| |8 |Trainer plug detect | | |8 |Trainer plug detect | | ||
| Line 31: | Line 32: | ||
| ^Pin ^Description ^ | ^Pin ^Description ^ | ||
| - | |0 (ADC_IN_8) |POT2 | | + | |0 (ADC_IN_8) |AUX4 POT | |
| - | |1 |LED Blue | | + | |1 |LED Green | |
| |2 |S.Port Update PWR | | |2 |S.Port Update PWR | | ||
| |3 |??? | | |3 |??? | | ||
| Line 41: | Line 42: | ||
| |8 |Haptic | | |8 |Haptic | | ||
| |9 (I2C WP) |EEPROM WP | | |9 (I2C WP) |EEPROM WP | | ||
| - | |10 |Bluetooth Tx | | + | |10 (USART_3_TX) |Bluetooth Tx | |
| - | |11 |Bluetooth Rx | | + | |11 (USART_3_RX) |Bluetooth Rx | |
| |12 (SPI2 CS) |SD Card Enable | | |12 (SPI2 CS) |SD Card Enable | | ||
| |13 (SPI2 SCK) |SD Card SCK | | |13 (SPI2 SCK) |SD Card SCK | | ||
| Line 52: | Line 53: | ||
| |0 (ADC_IN_10) |Voltage detect | | |0 (ADC_IN_10) |Voltage detect | | ||
| |1 |Button 'Trim LHR' | | |1 |Button 'Trim LHR' | | ||
| - | |2 |Buttom 'Trim RVU' | | + | |2 |Button 'Trim RVU' | |
| - | |3 |Buttom 'Trim RVD' | | + | |3 |Button 'Trim RVD' | |
| - | |4 |LED Green | | + | |4 |LED Blue | |
| |5 |LED Red | | |5 |LED Red | | ||
| |6 |Int Module PWR | | |6 |Int Module PWR | | ||
| Line 69: | Line 70: | ||
| - | |0 |Power button press | | + | |0 |Power on | |
| - | |1 |Power on | | + | |1 |Power button press | |
| |2 |Button 'Exit' | | |2 |Button 'Exit' | | ||
| |3 |Button 'Page' | | |3 |Button 'Page' | | ||
| Line 80: | Line 81: | ||
| |9 |SD Card Detect | | |9 |SD Card Detect | | ||
| |10 |??? | | |10 |??? | | ||
| - | |11 |Switch: C_11 | | + | |11 |Switch: C_L | |
| |12 |LCD RST | | |12 |LCD RST | | ||
| |13 |LCD Backlight | | |13 |LCD Backlight | | ||
| |14 |Switch H | | |14 |Switch H | | ||
| - | |15 |Trim LHL | | + | |15 |Button 'Trim LHL' | |
| Line 115: | Line 116: | ||
| ==== FCC Report ==== | ==== FCC Report ==== | ||
| - | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|XYF X91216DK]] | + | FCCID: [[https://fccid.io/2ANTI-T12|2ANTI-T12]] |
hardware/jumper_t12.1548511654.txt.gz (2300 views) · Last modified: 2019/01/26 06:07 by PhracturedBlue
