hardware:jumper_t12
hardware:jumper_t12 [2019/01/26 06:45] PhracturedBlue |
hardware:jumper_t12 [2019/04/26 15:22] (current) goebish [FCC Report] |
Line 18: | Line 19: | ||
Line 31: | Line 32: | ||
|3 |??? | | |3 |??? | | ||
Line 41: | Line 42: | ||
Line 54: | Line 55: | ||
|2 |Button 'Trim RVU' | | |2 |Button 'Trim RVU' | | ||
|3 |Button 'Trim RVD' | | |3 |Button 'Trim RVD' | | ||
Line 69: | Line 70: | ||
Line 115: | Line 116: | ||
hardware/jumper_t12.1548513956.txt.gz (59719 views) · Last modified: 2019/01/26 06:45 by PhracturedBlue
