hardware:radiolink_at10
hardware:radiolink_at10 [2016/04/20 07:11] PhracturedBlue created |
hardware:radiolink_at10 [2019/02/10 06:27] csujun |
===== Radiolink AT10 Hardware Connections ===== | ===== Radiolink AT10 Hardware Connections ===== | ||
- | Coming soon | + | The following documents the hardware inside the Radiolink AT9 transmitter |
- | Schematic is available here: | + | * MCU: [[http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF164491|STM32F103VET6]] 512kB Flash, 64kB RAM 100pin package |
+ | * EEPROM: [[http://www.giantec-semi.com/upload/datasheet/GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM | ||
+ | * LCD Display: FPC-SJ28N-19VOF | ||
+ | * LCD Driver: ILI9341 based 320x240x16bit display | ||
+ | * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver | ||
+ | * DC/DC converter: MC34063A | ||
+ | ==== STM32 Connections ==== | ||
+ | ^Pin ^Connection ^Description ^Additional Info^ | ||
+ | |BOOT0 |BOOT0 | | | | ||
+ | === GPIOA === | ||
+ | |PA00 | CH1 | SRH RIght Hor Stick | | | ||
+ | |PA01 | CH2 | SLV Left Ver Stick | | | ||
+ | |PA02 | CH3 | SRV Right Ver Stick | | | ||
+ | |PA03 | CH4 | SLH Left Hor Stick | | | ||
+ | |PA04 | POT | Right Shoulder VRE| | | ||
+ | |PA05 | POT | Left Front Dial VRA| | | ||
+ | |PA06 | POT | Right Front Dial VRB| | | ||
+ | |PA07 | POT | Center Front Dial VRC| | | ||
+ | |PA08 | K8H | 2-pos switch | RC filter | | ||
+ | |PA09 | TX | Boot connector | | | ||
+ | |PA10 | RX | Boot connector | | | ||
+ | |PA12 | LED RED | | To cathode through limiting resistor | | ||
+ | |PA13 | LED Green | | To cathode through limiting resistor | | ||
+ | |PA14 | ENTER | Menu button | 1K resistor to GND | | ||
+ | |PA15 | EXIT | Menu button | 1K resistor to GND | | ||
+ | === GPIOB === | ||
+ | |PB00 | POT | Left Shoulder VRD| | | ||
+ | |PB03 | TRL | Right Trim Left | | | ||
+ | |PB04 | TRR | Right Trim Right | | | ||
+ | |PB05 | TLU | Left Trim Up | | | ||
+ | |PB06 | TLD | Left Trim Down | | | ||
+ | |PB07 | PC OUT | PCM port | 4.7K limiting resistor | | ||
+ | |PB08 | PC IN | PCM port | 4.7K limiting resistor | | ||
+ | |PB09 | DISP24 | PWM for LEDs | Transistor to GND | | ||
+ | |PB11 | REST | RF board | | | ||
+ | |PB12 | CSN | RF board | | | ||
+ | |PB13 | SCK | RF board | | | ||
+ | |PB14 | MISO | RF board | | | ||
+ | |PB15 | MOSI | RF board | | | ||
+ | === GPIOC === | ||
+ | |PC00 | K1A | 2-pos switch | | | ||
+ | |PC01 | K2B | 2-pos switch | | | ||
+ | |PC02 | K3C1 | 3-pos switch | | | ||
+ | |PC03 | K3C2 | 3-pos switch | | | ||
+ | |PC04 | K5E1 | 3-pos switch | | | ||
+ | |PC05 | K5E2 | 3-pos switch | | | ||
+ | |PC06 | K4D | 2-pos switch | RC filter | | ||
+ | |PC07 | K6F | 2-pos switch | RC filter | | ||
+ | |PC08 | K7G | 2-pos switch | RC filter | | ||
+ | |PC09 | K8H | 2-pos switch | RC filter | | ||
+ | |PC10 | SDA | EEPROM | | | ||
+ | |PC11 | SCL | EEPROM | | | ||
+ | |PC12 | VIBRATOR | | Transistor | | ||
+ | |PC13 | ENC L | Rotary Encoder | 10K pull-up | | ||
+ | |PC14 | ENC R | Rotary Encoder | 10K pull-up | | ||
+ | |PC15 | ENC Button | Rotary Encoder | Direct to pin | | ||
+ | === GPIOD === | ||
+ | |PD00 | DISP5 | Data | | | ||
+ | |PD01 | DISP6 | Data | | | ||
+ | |PD02 | TRU | Right Trim Up | | | ||
+ | |PD03 | TRD | Right Trim Down | | | ||
+ | |PD04 | DISP21 | Control | | | ||
+ | |PD05 | DISP22 | Control | | | ||
+ | |PD07 | DISP20 | Control | | | ||
+ | |PD08 | DISP16 | Data | | | ||
+ | |PD09 | DISP17 | Data | | | ||
+ | |PD10 | DISP18 | Data | | | ||
+ | |PD11 | DISP23 | Control | | | ||
+ | |PD12 | TLL | Left Trim to Left | | | ||
+ | |PD13 | TLR | Left Trim to Right | | | ||
+ | |PD14 | DISP3 | Data | | | ||
+ | |PD15 | DISP4 | Data | | | ||
+ | === GPIOE === | ||
+ | |PE00 | DISP19 | RESx ILI9341 Pin | Reset is Active low | | ||
+ | |PE01 | POINT1 | | | | ||
+ | |PE02 | POINT2 | | | | ||
+ | |PE03 | POINT3 | | | | ||
+ | |PE04 | POINT4 | | | | ||
+ | |PE05 | POINT6 | | | | ||
+ | |PE07 | DISP7 | Data | | | ||
+ | |PE08 | DISP8 | Data | | | ||
+ | |PE09 | DISP9 | Data | | | ||
+ | |PE10 | DISP10 | Data | | | ||
+ | |PE11 | DISP11 | Data | | | ||
+ | |PE12 | DISP12 | Data | | | ||
+ | |PE13 | DISP13 | Data | | | ||
+ | |PE14 | DISP14 | Data | | | ||
+ | |PE15 | DISP15 | Data | | | ||
+ | | 15.05V | 0x0FFB | | ||
+ | | 10.02V | 0x0A9D | | ||
+ | | 4.31V | 0x048E | | ||
+ | === FCC Report === | ||
+ | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page| U2B RL039AT10]] | ||
+ | Schematic is available here (courtesy of FCC): | ||
{{:hardware:at10_schematics.pdf|}} | {{:hardware:at10_schematics.pdf|}} |
hardware/radiolink_at10.txt (119886 views) · Last modified: 2019/02/27 05:25 by csujun
