hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/08 00:15] csujun |
hardware:radiolink_at10 [2019/02/08 00:19] csujun |
Line 89: | Line 89: | ||
- | |PE02 | BUZZER | | Transistor | | + | |PE02-06 | POINT | | test point | |
hardware/radiolink_at10.txt (126456 views) ยท Last modified: 2019/02/27 05:25 by csujun
