hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/08 00:15] csujun |
hardware:radiolink_at10 [2019/02/08 00:20] csujun |
Line 88: | Line 88: | ||
- | |PE01 | LED Red | | To cathode through limiting resistor | | + | |PE01-06 | POINT | | test point | |
- | |PE02 | BUZZER | | Transistor | | + | |
hardware/radiolink_at10.txt (116373 views) · Last modified: 2019/02/27 05:25 by csujun
