hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/08 00:15] csujun |
hardware:radiolink_at10 [2019/02/15 04:52] csujun Add LCD Driver information |
Line 5: | Line 5: | ||
Line 19: | Line 19: | ||
Line 33: | Line 33: | ||
Line 58: | Line 58: | ||
Line 88: | Line 88: | ||
- | |PE02 | BUZZER | | Transistor | | + | |PE02 | POINT2 | | | |
+ | |PE03 | POINT3 | | | | ||
+ | |PE04 | POINT4 | | | | ||
+ | |PE05 | POINT6 | | | | ||
hardware/radiolink_at10.txt (125524 views) · Last modified: 2019/02/27 05:25 by csujun
