hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/10 06:27] csujun |
hardware:radiolink_at10 [2019/02/21 17:03] csujun red led connects PC12 |
Line 5: | Line 5: | ||
Line 23: | Line 23: | ||
|PA06 | POT | Right Front Dial VRB| | | |PA06 | POT | Right Front Dial VRB| | | ||
|PA07 | POT | Center Front Dial VRC| | | |PA07 | POT | Center Front Dial VRC| | | ||
- | |PA08 | K8H | 2-pos switch | RC filter | | ||
Line 63: | Line 61: | ||
|PC14 | ENC R | Rotary Encoder | 10K pull-up | | |PC14 | ENC R | Rotary Encoder | 10K pull-up | |
hardware/radiolink_at10.txt (126135 views) ยท Last modified: 2019/02/27 05:25 by csujun
