hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/10 06:27] csujun remove PA08 |
hardware:radiolink_at10 [2019/02/27 05:25] (current) csujun add PD6 |
Line 5: | Line 5: | ||
Line 26: | Line 26: | ||
Line 62: | Line 61: | ||
Line 75: | Line 74: | ||
|PD04 | DISP21 | Control | | | |PD04 | DISP21 | Control | | | ||
+ | |PD06 | USB DETECT | Detect USB Plugin | | | ||
|PD08 | DISP16 | Data | | | |PD08 | DISP16 | Data | | |
hardware/radiolink_at10.1549808862.txt.gz (126101 views) ยท Last modified: 2019/02/10 06:27 by csujun
