hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/07 17:03] csujun initial version copy form at9 |
hardware:radiolink_at10 [2019/02/10 06:27] csujun remove PA08 |
Line 19: | Line 19: | ||
+ | |PA12 | LED RED | | To cathode through limiting resistor | | ||
Line 31: | Line 33: | ||
Line 56: | Line 58: | ||
Line 86: | Line 88: | ||
- | |PE02 | BUZZER | | Transistor | | + | |PE02 | POINT2 | | | |
+ | |PE03 | POINT3 | | | | ||
+ | |PE04 | POINT4 | | | | ||
+ | |PE05 | POINT6 | | | | ||
hardware/radiolink_at10.txt (111263 views) · Last modified: 2019/02/27 05:25 by csujun
