hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/15 04:52]
csujun Add LCD Driver information
hardware:radiolink_at10 [2019/02/27 05:25]
csujun add PD6
Line 26: Line 26:
 |PA10    | RX         | Boot connector ​      | | |PA10    | RX         | Boot connector ​      | |
 |PA11    | BUZZ       | Buzzer ​              | | |PA11    | BUZZ       | Buzzer ​              | |
-|PA12    | LED RED    |                      | To cathode through limiting resistor |
 |PA13    | LED Green  |                      | To cathode through limiting resistor | |PA13    | LED Green  |                      | To cathode through limiting resistor |
 |PA14    | ENTER      | Menu button ​         | 1K resistor to GND | |PA14    | ENTER      | Menu button ​         | 1K resistor to GND |
Line 62: Line 61:
 |PC10    | SDA        | EEPROM ​              ​| ​ |  |PC10    | SDA        | EEPROM ​              ​| ​ |
 |PC11    | SCL        | EEPROM ​              ​| ​ |    |PC11    | SCL        | EEPROM ​              ​| ​ |
-|PC12    | VIBRATOR ​  |                      | Transistor ​|+|PC12    | LED RED    ​|                      | To cathode through limiting resistor ​|
 |PC13    | ENC L      | Rotary Encoder ​      | 10K pull-up | |PC13    | ENC L      | Rotary Encoder ​      | 10K pull-up |
 |PC14    | ENC R      | Rotary Encoder ​      | 10K pull-up | |PC14    | ENC R      | Rotary Encoder ​      | 10K pull-up |
Line 75: Line 74:
 |PD04    | DISP21 ​    | Control ​             |  | |PD04    | DISP21 ​    | Control ​             |  |
 |PD05    | DISP22 ​    | Control ​             |  | |PD05    | DISP22 ​    | Control ​             |  |
 +|PD06    | USB DETECT | Detect USB Plugin ​   |  |
 |PD07    | DISP20 ​    | Control ​             |  | |PD07    | DISP20 ​    | Control ​             |  |
 |PD08    | DISP16 ​    | Data                 ​| ​ | |PD08    | DISP16 ​    | Data                 ​| ​ |
hardware/radiolink_at10.txt (216327 views) ยท Last modified: 2019/02/27 05:25 by csujun
