hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/10 06:27]
csujun
hardware:radiolink_at10 [2019/02/27 05:25] (current)
csujun add PD6
Line 5: Line 5:
   * EEPROM: [[http://​www.giantec-semi.com/​upload/​datasheet/​GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM   * EEPROM: [[http://​www.giantec-semi.com/​upload/​datasheet/​GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM
   * LCD Display: FPC-SJ28N-19VOF   * LCD Display: FPC-SJ28N-19VOF
-  * LCD Driver: ​ILI9341 ​based 320x240x16bit ​display+  * LCD Driver: ​[[https://​pdf-datasheet-datasheet.netdna-ssl.com/​pdf-down/​S/​T/​7/​ST7796S-Sitronix.pdf|ST7789S]] ​based 320x480x16bit ​display
   * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver   * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver
   * DC/DC converter: MC34063A   * DC/DC converter: MC34063A
Line 23: Line 23:
 |PA06    | POT        | Right Front Dial  VRB| | |PA06    | POT        | Right Front Dial  VRB| |
 |PA07    | POT        | Center Front Dial VRC| | |PA07    | POT        | Center Front Dial VRC| |
-|PA08    | K8H        | 2-pos switch ​        | RC filter |
 |PA09    | TX         | Boot connector ​      | | |PA09    | TX         | Boot connector ​      | |
 |PA10    | RX         | Boot connector ​      | | |PA10    | RX         | Boot connector ​      | |
 |PA11    | BUZZ       | Buzzer ​              | | |PA11    | BUZZ       | Buzzer ​              | |
-|PA12    | LED RED    |                      | To cathode through limiting resistor |
 |PA13    | LED Green  |                      | To cathode through limiting resistor | |PA13    | LED Green  |                      | To cathode through limiting resistor |
 |PA14    | ENTER      | Menu button ​         | 1K resistor to GND | |PA14    | ENTER      | Menu button ​         | 1K resistor to GND |
Line 63: Line 61:
 |PC10    | SDA        | EEPROM ​              ​| ​ |  |PC10    | SDA        | EEPROM ​              ​| ​ |
 |PC11    | SCL        | EEPROM ​              ​| ​ |    |PC11    | SCL        | EEPROM ​              ​| ​ |
-|PC12    | VIBRATOR ​  |                      | Transistor ​|+|PC12    | LED RED    ​|                      | To cathode through limiting resistor ​|
 |PC13    | ENC L      | Rotary Encoder ​      | 10K pull-up | |PC13    | ENC L      | Rotary Encoder ​      | 10K pull-up |
 |PC14    | ENC R      | Rotary Encoder ​      | 10K pull-up | |PC14    | ENC R      | Rotary Encoder ​      | 10K pull-up |
Line 76: Line 74:
 |PD04    | DISP21 ​    | Control ​             |  | |PD04    | DISP21 ​    | Control ​             |  |
 |PD05    | DISP22 ​    | Control ​             |  | |PD05    | DISP22 ​    | Control ​             |  |
 +|PD06    | USB DETECT | Detect USB Plugin ​   |  |
 |PD07    | DISP20 ​    | Control ​             |  | |PD07    | DISP20 ​    | Control ​             |  |
 |PD08    | DISP16 ​    | Data                 ​| ​ | |PD08    | DISP16 ​    | Data                 ​| ​ |
hardware/radiolink_at10.1549808824.txt.gz (8175 views) · Last modified: 2019/02/10 06:27 by csujun
