hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/10 06:27] csujun remove PA08 |
hardware:radiolink_at10 [2019/02/27 05:25] (current) csujun add PD6 |
| Line 5: | Line 5: | ||
| * EEPROM: [[http://www.giantec-semi.com/upload/datasheet/GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM | * EEPROM: [[http://www.giantec-semi.com/upload/datasheet/GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM | ||
| * LCD Display: FPC-SJ28N-19VOF | * LCD Display: FPC-SJ28N-19VOF | ||
| - | * LCD Driver: ILI9341 based 320x240x16bit display | + | * LCD Driver: [[https://pdf-datasheet-datasheet.netdna-ssl.com/pdf-down/S/T/7/ST7796S-Sitronix.pdf|ST7789S]] based 320x480x16bit display |
| * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver | * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver | ||
| * DC/DC converter: MC34063A | * DC/DC converter: MC34063A | ||
| Line 26: | Line 26: | ||
| |PA10 | RX | Boot connector | | | |PA10 | RX | Boot connector | | | ||
| |PA11 | BUZZ | Buzzer | | | |PA11 | BUZZ | Buzzer | | | ||
| - | |PA12 | LED RED | | To cathode through limiting resistor | | ||
| |PA13 | LED Green | | To cathode through limiting resistor | | |PA13 | LED Green | | To cathode through limiting resistor | | ||
| |PA14 | ENTER | Menu button | 1K resistor to GND | | |PA14 | ENTER | Menu button | 1K resistor to GND | | ||
| Line 62: | Line 61: | ||
| |PC10 | SDA | EEPROM | | | |PC10 | SDA | EEPROM | | | ||
| |PC11 | SCL | EEPROM | | | |PC11 | SCL | EEPROM | | | ||
| - | |PC12 | VIBRATOR | | Transistor | | + | |PC12 | LED RED | | To cathode through limiting resistor | |
| |PC13 | ENC L | Rotary Encoder | 10K pull-up | | |PC13 | ENC L | Rotary Encoder | 10K pull-up | | ||
| |PC14 | ENC R | Rotary Encoder | 10K pull-up | | |PC14 | ENC R | Rotary Encoder | 10K pull-up | | ||
| Line 75: | Line 74: | ||
| |PD04 | DISP21 | Control | | | |PD04 | DISP21 | Control | | | ||
| |PD05 | DISP22 | Control | | | |PD05 | DISP22 | Control | | | ||
| + | |PD06 | USB DETECT | Detect USB Plugin | | | ||
| |PD07 | DISP20 | Control | | | |PD07 | DISP20 | Control | | | ||
| |PD08 | DISP16 | Data | | | |PD08 | DISP16 | Data | | | ||
hardware/radiolink_at10.1549808862.txt.gz (4936 views) ยท Last modified: 2019/02/10 06:27 by csujun
