hardware:radiolink_at9
hardware:radiolink_at9 [2016/04/30 20:34] PhracturedBlue |
hardware:radiolink_at9 [2019/02/27 05:21] csujun add PD6 |
The following documents the hardware inside the Radiolink AT9 transmitter | The following documents the hardware inside the Radiolink AT9 transmitter | ||
- | * MCU: [[http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF164491|STM32F103VCT6]] 512kB Flash, 64kB RAM 100pin package | + | * MCU: [[http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF164491|STM32F103VET6]] 512kB Flash, 64kB RAM 100pin package |
- | * LCD Driver: ILI9341 based 320x240x1bit display | + | * LCD Driver: ILI9341 based 320x240x16bit display |
Line 20: | Line 20: | ||
+ | |PA04 | POT | Right Shoulder | | | ||
+ | |PA05 | POT | Left Front Dial | | | ||
+ | |PA06 | POT | Right Front Dial | | | ||
Line 29: | Line 32: | ||
|PB04 | TRR | Right Trim Right | | | |PB04 | TRR | Right Trim Right | | | ||
Line 70: | Line 75: | ||
+ | |PD06 | USB Detect | Detect USB Plugin | | | ||
|PD09 | DISP17 | Data | | | |PD09 | DISP17 | Data | | | ||
Line 81: | Line 87: | ||
- | |PE00 | LCDRESx | Reset Pin for LCD | Reset is Active low | | + | |PE00 | DISP19 | RESx ILI9341 Pin | Reset is Active low | |
Line 93: | Line 99: | ||
+ | | 15.05V | 0x0FFB | | ||
+ | | 10.02V | 0x0A9D | | ||
+ | | 4.31V | 0x048E | | ||
=== FCC Report === | === FCC Report === |
hardware/radiolink_at9.txt (205482 views) ยท Last modified: 2019/02/27 05:21 by csujun
