hardware:radiolink_at9
hardware:radiolink_at9 [2016/04/30 21:09]
PhracturedBlue
hardware:radiolink_at9 [2019/02/27 05:21] (current)
csujun add PD6
Line 3: Line 3:
 The following documents the hardware inside the Radiolink AT9 transmitter The following documents the hardware inside the Radiolink AT9 transmitter
-  * MCU: [[http://​www.st.com/​web/​catalog/​mmc/​FM141/​SC1169/​SS1031/​LN1565/​PF164491|STM32F103VCT6]] 512kB Flash, 64kB RAM 100pin package+  * MCU: [[http://​www.st.com/​web/​catalog/​mmc/​FM141/​SC1169/​SS1031/​LN1565/​PF164491|STM32F103VET6]] 512kB Flash, 64kB RAM 100pin package
   * EEPROM: [[http://​www.giantec-semi.com/​upload/​datasheet/​GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM   * EEPROM: [[http://​www.giantec-semi.com/​upload/​datasheet/​GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM
   * LCD Display: FPC-SJ28N-19VOF   * LCD Display: FPC-SJ28N-19VOF
-  * LCD Driver: ILI9341 based 320x240x1bit ​display+  * LCD Driver: ILI9341 based 320x240x16bit ​display
   * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver   * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver
   * DC/DC converter: MC34063A   * DC/DC converter: MC34063A
Line 20: Line 20:
 |PA02    | CH3        | SRV Right Ver Stick  | | |PA02    | CH3        | SRV Right Ver Stick  | |
 |PA03    | CH4        | SLH Left Hor Stick   | | |PA03    | CH4        | SLH Left Hor Stick   | |
 +|PA04    | POT        | Right Shoulder ​      | |
 +|PA05    | POT        | Left Front Dial      | |
 +|PA06    | POT        | Right Front Dial     | |
 |PA08    | K8H        | 2-pos switch ​        | RC filter | |PA08    | K8H        | 2-pos switch ​        | RC filter |
 |PA09    | TX         | Boot connector ​      | | |PA09    | TX         | Boot connector ​      | |
Line 29: Line 32:
 === GPIOB === === GPIOB ===
 ^Pin     ​^Connection ​ ^Description ​          ​^Additional Info^ ^Pin     ​^Connection ​ ^Description ​          ​^Additional Info^
 +|PB00    | POT        | Left Shoulder ​       | |
 +|PB01    | LOWBAT ​    | Battery Voltage ​     | |
 |PB03    | TRL        | Right Trim Left      | | |PB03    | TRL        | Right Trim Left      | |
 |PB04    | TRR        | Right Trim Right     | | |PB04    | TRR        | Right Trim Right     | |
Line 70: Line 75:
 |PD05    | DISP22 ​    | Control ​             |  | |PD05    | DISP22 ​    | Control ​             |  |
 |PD07    | DISP20 ​    | Control ​             |  | |PD07    | DISP20 ​    | Control ​             |  |
 +|PD06    | USB Detect | Detect USB Plugin ​   |  |
 |PD08    | DISP16 ​    | Data                 ​| ​ | |PD08    | DISP16 ​    | Data                 ​| ​ |
 |PD09    | DISP17 ​    | Data                 ​| ​ | |PD09    | DISP17 ​    | Data                 ​| ​ |
Line 93: Line 99:
 |PE14    | DISP14 ​    | Data                 ​| ​ | |PE14    | DISP14 ​    | Data                 ​| ​ |
 |PE15    | DISP15 ​    | Data                 ​| ​ | |PE15    | DISP15 ​    | Data                 ​| ​ |
 +=== Battery Voltage Measurement ===
 +The battery voltage (ADC1_9) was measured as:
 +^ Voltage ^ ADC Value ^
 +| 15.05V ​ | 0x0FFB ​   |
 +| 10.02V ​ | 0x0A9D ​   |
 +|  4.31V  | 0x048E ​   |
 +is calculated by the formula: ​
 +V = 0.003672 * value + 0.0287
 === FCC Report === === FCC Report ===
hardware/radiolink_at9.1462075742.txt.gz (7405 views) ยท Last modified: 2016/04/30 21:09 by PhracturedBlue
