installing_on_f_series
installing_on_f_series [2016/05/30 15:48]
Arnold [Installing Deviation on the F12e/F7/F4]
installing_on_f_series [2017/03/22 10:31] (current)
FDR BuildFS download link
Line 3: Line 3:
 The Walkera F-series transmitters have a very small Flash space. ​ Too small for the traditional FAT fielsystem used by Deviation for other Walkera transmitters. ​ Instead a custom filesystem was designed for these cases called '​DevoFS' ​ The filesystem installation is different because of this. The Walkera F-series transmitters have a very small Flash space. ​ Too small for the traditional FAT fielsystem used by Deviation for other Walkera transmitters. ​ Instead a custom filesystem was designed for these cases called '​DevoFS' ​ The filesystem installation is different because of this.
-After following the typical installation (using the DfuSe tool, or Deviation Uploader to install the dfu file), rebooting the transmitter should result in a screen that says '​Deviation USB'+After following the typical installation (using the DfuSe tool, or <del>Deviation Uploader</​del>//​-Note that only a custom build of the deviation-uploader works with the F4/F7, the recommendation is to stick with the Walkera DfuSe tool-// ​to install the dfu file), rebooting the transmitter should result in a screen that says '​Deviation USB'
 At this point, if you plug the transmitter into the PC via USB it should be detected as an external drive with a single file '​devo.fs' ​ This is a trick used in Deviation to provide a mechanism to directly access the filesystem. ​ Do not attempt to delete this file or to format the filesystem. ​ These tasks will not damage your transmitter,​ but they also will have no affect. At this point, if you plug the transmitter into the PC via USB it should be detected as an external drive with a single file '​devo.fs' ​ This is a trick used in Deviation to provide a mechanism to directly access the filesystem. ​ Do not attempt to delete this file or to format the filesystem. ​ These tasks will not damage your transmitter,​ but they also will have no affect.
Line 15: Line 15:
 First you will need the buildfs program. ​ If you use Windows, you can download the compiled version here: First you will need the buildfs program. ​ If you use Windows, you can download the compiled version here:
-https://dl.dropboxusercontent.com/u/52854517/buildfs.exe+[[https://www.deviationtx.com/downloads-new/category/3-miscellaneous?​download=5092:​buildfs-exe|Download BuildFS]]
 Or you can use the python script (you need to have python2.7 installed) here:  Or you can use the python script (you need to have python2.7 installed) here:
installing_on_f_series.1464648499.txt.gz (4941 views) ยท Last modified: 2016/05/30 15:48 by Arnold
