model5
model5 [2018/01/16 20:00] MikeNH |
model5 [2018/01/16 20:05] MikeNH |
- | NOTE: The formatting is correct only when in Edit made. I don;t know why.\\ | ||
name=Babyhawk\\ | name=Babyhawk\\ | ||
mixermode=Advanced\\ | mixermode=Advanced\\ | ||
Line 8: | Line 6: | ||
num_channels=12\\ | num_channels=12\\ | ||
tx_power=150mW\\ | tx_power=150mW\\ | ||
- | [protocol_opts] | + | [protocol_opts]\\ |
- | Failsafe=Hold | + | Failsafe=Hold\\ |
- | AD2GAIN=100 | + | AD2GAIN=100\\ |
- | Freq-Fine=0 | + | Freq-Fine=0\\ |
- | Format=FCC | + | Format=FCC\\ |
- | RSSIChan=None | + | RSSIChan=None\\ |
- | S.PORT Out=Disabled | + | S.PORT Out=Disabled\\ |
- | [channel1] | + | [channel1]\\ |
- | reverse=1 | + | reverse=1\\ |
- | template=simple | + | template=simple\\ |
- | [mixer] | + | [mixer]\\ |
- | src=AIL | + | src=AIL\\ |
- | dest=Ch1 | + | dest=Ch1\\ |
- | [channel2] | + | [channel2]\\ |
- | src=ELE | + | src=ELE\\ |
- | dest=Ch2 | + | dest=Ch2\\ |
- | [channel3] | + | [channel3]\\ |
- | src=THR | + | src=THR\\ |
- | dest=Ch3 | + | dest=Ch3\\ |
- | [channel4] | + | [channel4]\\ |
- | src=RUD | + | src=RUD\\ |
- | dest=Ch4 | + | dest=Ch4\\ |
- | [channel5] | + | [channel5]\\ |
- | src=HOLD1 | + | src=HOLD1\\ |
- | dest=Ch5 | + | dest=Ch5\\ |
- | curvetype=min/max | + | curvetype=min/max\\ |
- | points=0 | + | points=0\\ |
- | [channel6] | + | [channel6]\\ |
- | src=FMODE1 | + | src=FMODE1\\ |
- | dest=Ch6 | + | dest=Ch6\\ |
- | [channel7] | + | [channel7]\\ |
- | max=100 | + | max=100\\ |
- | scalar-=100 | + | scalar-=100\\ |
- | min=-100 | + | min=-100\\ |
- | src=Virt1 | + | src=Virt1\\ |
- | dest=Ch7 | + | dest=Ch7\\ |
- | curvetype=expo | + | curvetype=expo\\ |
- | points=0,0 | + | points=0,0\\ |
- | [channel8] | + | [channel8]\\ |
- | src=Virt2 | + | src=Virt2\\ |
- | dest=Ch8 | + | dest=Ch8\\ |
- | [channel9] | + | [channel9]\\ |
- | src=Virt3 | + | src=Virt3\\ |
- | dest=Ch9 | + | dest=Ch9\\ |
- | curvetype=3point | + | curvetype=3point\\ |
- | points=0,0,0 | + | points=0,0,0\\ |
- | [channel10] | + | [channel10]\\ |
- | src=Virt4 | + | src=Virt4\\ |
- | dest=Ch10 | + | dest=Ch10\\ |
[virtchan1] | [virtchan1] | ||
name=Modes | name=Modes |
model5.txt (108011 views) · Last modified: 2018/01/16 20:09 by MikeNH
