model_config:dji_phantom_-_just_a_little_help_needed:djiphantom
name=DJI PHANTOM mixermode=Advanced icon=heli.bmp [radio] protocol=DEVO num_channels=8 fixed_id=874067 tx_power=150mW [protocol_opts] Telemetry=On [channel1] template=simple [mixer] src=ELE dest=Ch1 curvetype=expo points=0,0 [channel2] reverse=1 template=simple [mixer] src=AIL dest=Ch2 curvetype=expo points=0,0 [channel3] failsafe=-25 safetyval=-110 min=-151 template=simple [mixer] src=THR dest=Ch3 curvetype=expo points=0,0 [channel4] reverse=1 template=simple [mixer] src=RUD dest=Ch4 curvetype=expo points=0,0 [channel5] failsafe=35 template=expo_dr [mixer] src=FMODE0 dest=Ch5 scalar=90 curvetype=absval points=0 [mixer] src=FMODE0 dest=Ch5 switch=FMODE1 scalar=7 curvetype=absval points=0 [mixer] src=FMODE0 dest=Ch5 switch=FMODE2 scalar=-77 curvetype=absval points=0 [channel6] template=simple [mixer] src=FMODE0 dest=Ch6 switch=FMODE2 scalar=-79 curvetype=expo points=0,0 [channel7] template=expo_dr [mixer] src=MIX0 dest=Ch7 scalar=95 curvetype=absval points=0 [mixer] src=MIX0 dest=Ch7 switch=MIX1 scalar=5 curvetype=absval points=0 [mixer] src=MIX0 dest=Ch7 switch=MIX2 scalar=-80 curvetype=absval points=0 [trim1] src=LEFT_V pos=TRIMLV+ neg=TRIMLV- value=2,0,0 [trim2] src=RIGHT_V pos=TRIMRV+ neg=TRIMRV- [trim3] src=LEFT_H pos=TRIMLH+ neg=TRIMLH- value=4,0,0 [trim4] src=RIGHT_H pos=TRIMRH+ neg=TRIMRH- value=100,0,0 [timer1] type=countdown src=GEAR1 resetsrc=RUD DR0 time=600 [telemalarm1] source=Volt2 above=1 value=110 [telemalarm2] source=Volt2 above=1 value=105 [telemalarm3] source=Temp1 value=40 [telemalarm4] source=Temp2 value=40 [telemalarm5] source=Temp3 value=40 [telemalarm6] source=Temp4 value=40 [datalog] switch=None rate=1 sec [safety] Auto=min [gui-128x64] V-trim=59,10,1 H-trim=5,59,3 V-trim=65,10,2 H-trim=74,59,4 Small-box=2,22,Ch3 Small-box=2,31,Timer1 Small-box=2,39,Timer2 Model=75,20 Battery=102,1 Toggle=4,10,0,3,0,RUD DR Toggle=13,10,0,5,0,ELE DR Toggle=22,10,0,4,0,AIL DR Toggle=31,10,0,0,0,None Toggle=40,10,0,0,0,None TxPower=102,7 quickpage1=Telemetry monitor
model_config/dji_phantom_-_just_a_little_help_needed/djiphantom.txt (15211 views) · Last modified: 2014/04/19 09:18 by bobnatale
