model_config:kk2_0_multirotor
model_config:kk2_0_multirotor [2014/01/20 07:33] Tom Z created1480982595 |
model_config:kk2_0_multirotor [2016/12/05 16:11] Arnold |
Line 5: | Line 5: | ||
KK2.0 Multirotor with the Devo Receiver. | KK2.0 Multirotor with the Devo Receiver. | ||
- | I am using the Spektrum AR6100 6 Channel Receiver 2.4 GHz DSM2 | + | I am using the Spektrum AR6100 6 Channel Receiver 2.4 GHz, Protocol=DSM2. |
If you have a Spektrum Receiver with DSMX you might have to switch the Protocol=DSM2 to Protocol=DSMX | If you have a Spektrum Receiver with DSMX you might have to switch the Protocol=DSM2 to Protocol=DSMX | ||
Line 17: | Line 17: | ||
* These models will not work for deviation firmware v2.1 or v3. | * These models will not work for deviation firmware v2.1 or v3. | ||
- | ** These models will work on the Devo 7e also but due to there is one less flight mode on that model you will not have all three flight modes. You will only have Flight Mode 1 and Flight Mode 2. | + | ** These models will work on the Devo 7e also but due to there being one less flight mode on that Devo you will not have all three flight modes. You will only have Flight Mode 1 and Flight Mode 2. |
I just test flew this model on my Devo 10. | I just test flew this model on my Devo 10. | ||
Line 33: | Line 33: | ||
Make sure the Bind Plug has the wire going from one end to the other end. There are some bind plugs that have the wire going from the center to one end (Walkera uses these), don't use this to bind the receiver as it will not work and might damage the receiver. | Make sure the Bind Plug has the wire going from one end to the other end. There are some bind plugs that have the wire going from the center to one end (Walkera uses these), don't use this to bind the receiver as it will not work and might damage the receiver. | ||
- | Power up the KK2.0 with the bind plug connected, turn on the Devo Transmitter, | + | Power up the KK2.0 with the bind plug connected, turn on the Devo Transmitter, go to (1) Model menu, (1) Model menu, scroll down to "Bind" and select it. The Devo Transmitter will now bind to the Spektrum Receiver. |
- | go to (1) Model menu, (1) Model menu, scroll down to "Bind" and select it. The Devo Transmitter will now bind to the Spektrum Receiver. | + | |
Once the bind is completed power off the KK2.0 and transmitter and remove the Bind Plug from the Spektrum Receiver. | Once the bind is completed power off the KK2.0 and transmitter and remove the Bind Plug from the Spektrum Receiver. | ||
Line 85: | Line 83: | ||
Install the configuration settings file into your models folder (See my How to video below). | Install the configuration settings file into your models folder (See my How to video below). | ||
- | This will over-right the current file so make sure that model slot doesnt | + | This will overwrite the current file so make sure that model slot doesn't have a model being used in it. If it does rename the configuration settings file to another number that you have free. |
- | have a model being used in it. If it does rename the configuration settings file | + | |
- | to another number that you have free. | + | |
- | Example: The file you downloaded is named model5 so change the 5" to another slot | + | |
- | number that you dont have a model setup for. If you have model slot 6 open rename the file to model6 | + | Example: The file you downloaded is named model5 so change the 5" to another slot number that you dont have a model setup for. If you have model slot 6 open rename the file to model6 |
How to Import/Export Deviation Firmware Models | How to Import/Export Deviation Firmware Models |
model_config/kk2_0_multirotor.txt (41064 views) · Last modified: 2016/12/05 16:11 by Arnold
