modulelist:3-in-1_module
modulelist:3-in-1_module [2016/11/24 14:22] Arnold created |
modulelist:3-in-1_module [2017/01/27 11:32] Arnold added photo |
- | **3-in-1 Module** | + | ==== 3-in-1 Module ==== |
+ | By installing this module in your Devo (with Deviation firmware installed) you can have 3 additional radios beyond the standard Devo CYRF module: the A7105, CC2500, and NRF24L01 modules are all contained in this single package and they will all use a common antenna connection, separate from the CYRF antenna. | ||
modulelist/3-in-1_module.txt (48584 views) · Last modified: 2018/04/04 15:47 by Arnold
