modulelist:3-in-1_module
modulelist:3-in-1_module [2017/01/27 11:32] Arnold added photo |
modulelist:3-in-1_module [2017/01/27 11:36] Arnold |
- | By installing this module in your Devo (with Deviation firmware installed) you can have 3 additional radios beyond the standard Devo CYRF module: the A7105, CC2500, and NRF24L01 modules are all contained in this single package and they will all use a common antenna connection, separate from the CYRF antenna. | + | By installing this module in your Devo (with Deviation firmware installed) you can have 3 additional radios beyond the standard Devo CYRF module: the A7105, CC2500, and NRF24L01 modules are all contained in this single package and they will all use a common antenna connection, separate from the CYRF antenna. (Click on image for a close-up view. And click on the close-up view for a detailed view.) |
{{ :modulelist:20161114_125906.jpg?direct&300 |}} | {{ :modulelist:20161114_125906.jpg?direct&300 |}} |
modulelist/3-in-1_module.txt (39254 views) ยท Last modified: 2018/04/04 15:47 by Arnold
