modulelist:3-in-1_module
modulelist:3-in-1_module [2016/11/24 15:08] Arnold |
- | By installing this module in your Devo (with Deviayion firmware installed) you will have 3 additional modules beyond the standard Devo CYRF module: the A7105, CC2500, and NRF24L01 modules are contained in this single package and they will each use a common antenna connection, separate from the CYRF antenna. | + | By installing this module in your Devo (with Deviation firmware installed) you can have 3 additional radios beyond the standard Devo CYRF module (which is factory-installed in all Walkera Devo transmitters) : the A7105, CC2500, and NRF24L01 modules are all contained in this single package and they will all use a common antenna connection, separate from the CYRF antenna. (Click on image for a close-up view. And click on the close-up view for a detailed view.) |
modulelist/3-in-1_module.1480028906.txt.gz (46581 views) · Last modified: 2016/11/24 15:08 by Arnold
