modulelist:3-in-1_module
modulelist:3-in-1_module [2016/11/24 14:33]
Arnold
modulelist:3-in-1_module [2018/04/04 15:47] (current)
Arnold
Line 1: Line 1:
 ==== 3-in-1 Module ==== ==== 3-in-1 Module ====
-By installing this module in your Devo you will have 3 additional ​modules ​beyond the standard Devo CYRF module: the A7105, CC2500, and NRF23L01 ​modules are contained in this single package and they will each use a common antenna connection, separate from the CYRF antenna.+By installing this module in your Devo (with Deviation firmware installed) ​you can have 3 additional ​radios ​beyond the standard Devo CYRF module ​(which is factory-installed in all Walkera Devo transmitters) ​: the A7105, CC2500, and NRF24L01 ​modules are all contained in this single package and they will all use a common antenna connection, separate from the CYRF antenna. ​(Click on image for a close-up view. And click on the close-up view for a detailed view.)
 +{{ :​modulelist:​20161114_125906.jpg?​direct&​300 |}}
modulelist/3-in-1_module.1480026808.txt.gz (5970 views) · Last modified: 2016/11/24 14:33 by Arnold
