modulelist:3-in-1_module
modulelist:3-in-1_module [2016/11/24 14:35] Arnold |
| Line 1: | Line 1: | ||
| ==== 3-in-1 Module ==== | ==== 3-in-1 Module ==== | ||
| - | By installing this module in your Devo you will have 3 additional modules beyond the standard Devo CYRF module: the A7105, CC2500, and NRF24L01 modules are contained in this single package and they will each use a common antenna connection, separate from the CYRF antenna. | + | By installing this module in your Devo (with Deviation firmware installed) you can have 3 additional radios beyond the standard Devo CYRF module (which is factory-installed in all Walkera Devo transmitters) : the A7105, CC2500, and NRF24L01 modules are all contained in this single package and they will all use a common antenna connection, separate from the CYRF antenna. (Click on image for a close-up view. And click on the close-up view for a detailed view.) |
| + | {{ :modulelist:20161114_125906.jpg?direct&300 |}} | ||
modulelist/3-in-1_module.1480026923.txt.gz (5976 views) · Last modified: 2016/11/24 14:35 by Arnold
