modulelist:4-in-1_module [2016/12/01 14:10] Arnold |
modulelist:4-in-1_module [2017/02/13 21:15] Arnold |
- | Read post #55157 by Vlad_vy for guidance on soldering to various Devo radios. | + | Read post #55157 by Vlad_vy [[https://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module?start=940#55157]] for guidance on soldering to various controllers, along with the associated hardware.ini file settings for enabling the modules in Deviation. **Note: You must __NOT__ be logged in to the Forum for the above link to work properly. |
modulelist/4-in-1_module.txt (13705 views) · Last modified: 2017/02/13 21:16 by Arnold
