modulelist:4-in-1_module [2016/12/29 12:28] Arnold |
modulelist:4-in-1_module [2017/01/15 08:05] vlad_vy |
Line 5: | Line 5: | ||
Shown below is the Devo 4-in-1 Module with the Devo daughter board, made specifically for the Devo line of radios. Once you plug it in to the existing socket (on Devos other than the 7E), only 3 more connections are needed from the board to the radio; one each for enabling the A7105, CC2500, and NRF24L01 components that are under the metal shield. Click on an image for a detailed close-up view. | Shown below is the Devo 4-in-1 Module with the Devo daughter board, made specifically for the Devo line of radios. Once you plug it in to the existing socket (on Devos other than the 7E), only 3 more connections are needed from the board to the radio; one each for enabling the A7105, CC2500, and NRF24L01 components that are under the metal shield. Click on an image for a detailed close-up view. | ||
- | Read post #55157 by Vlad_vy [[http://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module?start=940#55157]] for guidance on soldering to various radios, along with the associated hardware.ini file settings for enabling the modules in Deviation. | + | Read post #55157 by Vlad_vy [[http://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module?start=940#55157]] for guidance on soldering to various radios, along with the associated hardware.ini file settings for enabling the modules in Deviation. **Note: You must be logged in to the Forum for the link to work properly. |
modulelist/4-in-1_module.txt (28813 views) · Last modified: 2017/02/13 21:16 by Arnold
