modulelist:4-in-1_module [2016/12/01 14:23] Arnold |
modulelist:4-in-1_module [2017/02/13 21:15] Arnold |
- | Read post #55157 by Vlad_vy in the following thread for guidance on soldering to various Devo radios. | + | |
- | [[http://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module]] | + | |
modulelist/4-in-1_module.txt (9007 views) · Last modified: 2017/02/13 21:16 by Arnold
